Marine timing co er for Ford 460
rcyoung1
Looking for a marine front timig cover for a 460 with provision for a mechanical fuel lump. These seem to be about as rare as hen's teeth.
Any leads will be appreciated.
rcyoung1- Posts : 5
Re: Marine timing co er for Ford 460
What's the difference? Can't say I've ever seen a 460 marine engine.
stanger68- Posts : 500
Is it for an omc 460?.... If so there are 2 on eBay right now
Bosskk1786- Posts : 96
Alot of jet boats had 460 Fords.
The difference that the 4 lower bolts are all the same length and are flush with the cover lower pprtion.
rcyoung1- Posts : 5
Are you seeking any aftermarket marine application timing cover a la Nicson, etc?rcyoung1 wrote:Looking for a marine front timig cover for a 460 with provision for a mechanical fuel lump. These seem to be about as rare as hen's teeth.
Or do you specifically mean the ultra-rare, cast iron OEM 460 Marine timing cover that is very similar to the 429 Commercial engine timing cover?
Yup, a Nicson or equivalent is what I need.
Building a Ford powered drag boat.
rcyoung1- Posts : 5
If you look on craigslist Detroit metro there is 460 jet boat parts. They're a bunch of jet boat parts including a special timing cover
It is a nicson cover. I don't know how to copy and paste the link
here you go https://detroit.craigslist.org/mcb/bpo/d/ford-460-drive-engine-parts/6414336214.html
Mike R- Posts : 1381
you might think I am being too picky but that timing cover won't work. That one has built in mouting feet for connecting directly to the boat stringers. I am looking for a cover that accepts a front motor plate to mount the engine to the boat stringers. Also it does appear that that cover has a provision for a mechanical fuel pump.
It doesn't look like the will ship. He wants local pickup and cash only.
Thanks for the heads up.
The.boat stringers are the functionaly the same as a car frame
rcyoung1- Posts : 5
duplicate message, please ignore
rcyoung1- Posts : 5
I have what you're looking for. Shoot me a text & I can send pics, (775)3042370
Skipped_link- Posts : 20
