Ford C6
Gregaust
Ford C6
This what I've done in my lifetime to give the Ford guy that choose not to run a Chev transmission!
Frank Merkl- Posts : 1524
Re: Ford C6
4140 billet steel forward drum , 7075 T6 Aluminum billet Direct Drum , 300M input shaft and "NOW" 4130 CM billet pressure plates for your Forward and Direct Drums !!
Re: Ford C6
that's almost $100k in CNC programs ! and am I going to make money 'NO' will the C6 be a racing transmission "YES'
Re: Ford C6
I'm just a dumb farmer that likes peeing in the chevy guy's Corn Flakes!! LOL
Re: Ford C6
the billet PP 's are because over time the stock powered metal PP shatter over time at racing pressures
Re: Ford C6
Does the band tend to "track" the aluminum drum; is that aluminum hard coat anodized ...?
We had that trouble with the aluminum "turbo" drum when the band was simply used for decel...
Looks like needed stuff, though ... good job.
Re: Ford C6
the drum is not hard anodized , using the Red Alto 2 1/2" wide band seem to work , I was told though that if you used a kevlar band on it you'd have trouble .
Re: Ford C6
[size=62]I've got one in my new C6 all set up and ready to go, just need a 2nd gear brake to go with it [/size]
68formalGT- Posts : 865
Re: Ford C6
Good job with the transmissions Frank. I appreciate it.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Re: Ford C6
Thanks Charlie ! it means alot! This has been a lifetime of work for me ! To give the Ford Guy's a reliable transmission that works !
Re: Ford C6
PS that doesn't cost an arm and leg!! to build
Re: Ford C6
Frank Merkl wrote:PS that doesn't cost an arm and leg!! to build
And you won't be going through it 2-3 times in a season.
Re: Ford C6
Very Cool Frank
FalconEh- Posts : 1448
» We had a forum member set low ET for a Ford at the Annual Ford v Chevy race last weekend.
» Let's see your "unusual"Cool HotRod pic's. Ford and Non Ford
» mad dog headers off a 79 ford work on a 84 ford?
» look at this bad azz 23 ford
» FS: 1967 Ford Custom 2 door sedan with '67 Ford Custom parts car (Galaxie body)
