Making Sense of Cylinder Head Flow Testing
Old blue Racin Team
this is a recent article that i read ......
We all have heard the statement that an engine is an air pump; the more air it can pump the higher the output will be. The industry standard for quantifying the amount of air passing through the induction system is a flow bench test. It's commonplace to reference airflow numbers for cylinder heads in conversation and advertisements. The problem is how to decipher this information. If you are like most people, you work under the assumption that more flow is better. But that's not always true. If you ever wanted to understand flow bench testing, read on. And don't forget to check out the next issue for Part II of this story.
Why test for airflow?
One of the theories used to make power in an engine is airflow; so then measuring airflow, in theory, should enable one to establish potential output. The performance industry is focused on maximizing an engine's output on an individual component basis. Then documented gains in airflow should produce predictable results in power production. The question could then be posed, why look at airflow and not power? Whenever designing or modifying components in the induction tract of an engine, the ideal procedure would be to install the part and then dyno check. This would not only be the most accurate, but also the least practical test method. Anyone who has ever ported a cylinder head while quantifying results on a flow bench can only imagine the arduous process of installing the head and running the engine after every port change. Early on it was recognized that a better method needed to be developed, and that was the flow test. A flow bench allows a quick and easy means of quantifying gains or losses to airflow.
On a dyno, air movement into the engine is registered through an airflow meter, installed in a large funnel-like apparatus referred to as a dyno hat. It attaches to the carburetor or throttle body and measures the total airflow into the engine in terms of volumetric efficiency (VE), or the amount of charge fill in the bore. Believing that an engine completely fills the bores on every stroke would be incorrect. The swept volume of the cylinder is filled to the greatest capacity during peak torque production. On most normally aspirated engines a maximum of 85 percent VE is achieved at peak torque. On some very defined race applications, values of 100 percent or slightly above are realized. Forced induction can raise VE to 150 percent or greater. VE levels of over 100 percent on normally aspirated engines are achieved through intake manifold resonance tuning identified as inertia supercharging: the column of air is moving with such energy that it actually fills the cylinders beyond capacity by compressing the molecules and increasing the air density in the bore.In contrast, the flow bench is a series of vacuum motors and registers airflow by measuring it at a constant pressure. Test data derived on a flow bench is measured in cubic feet of air per minute (CFM). Often it may not relate directly to horsepower potential. Flow bench tests do not have the ability to induce inertia supercharging or demonstrate the effects that other components of the engine have on VE. A bi-directional flow bench has the ability to measure air movement in two directions. Intake and exhaust components can be tested.
The flow Test
During a test, the subject component is mounted on the flow bench and secured to the test fixture in some manner. There is no prescribed method of attachment. Usually it consists of nothing more than large Vise-Grips or C-clamps along with some type of gasket. When testing a cylinder head, an adapter the same size as the bore is necessary. This maintains the relationship of bore shrouding that the cylinder head will experience on the engine. An opening fixture is used to actuate the valve to specific lift points. Lightweight test springs are installed to keep tension on the valve. When measuring flow on the intake side, more accurate results will be obtained with a radius on the inlet port in lieu of the straight edge of the cylinder head casting. When testing the exhaust port it's necessary to attach a six-inch extension for the same reason. The radiused inlet along with the exhaust extension allows for a smoother transition. Without these fixtures, the air will shear and give readings that are lower than the actual potential of the port. Radiused inlets can be formed with modeling clay while pre-made Plexiglas units to a specified intake manifold gasket size are available. The exhaust extension is customarily a 1.75- to 2-inch piece of straight exhaust pipe.
Of paramount concern is repeatable test procedures when checking a modification. The most common component for flow testing is the cylinder head and that is also a component where many mistakes in the test can be made. Whenever comparing flow data from different benches there will always be a slight variation due to operator error, calibration of the bench, fixturing, electrical current and air temperature. Working with a cylinder head, a large variation in flow numbers can be achieved by using different-sized bore adapters. This is a common mistake since many shops assume that in the case of a small-block Chevy, the bore is 4.030 inches. A cylinder head that is flowed on a larger bore may very well show improved flow numbers from the additional unshrouding.
A flow bench test is done at a fixed test pressure. Due to this, the test value will need to be identified. Higher test pressures yield higher flow numbers. SuperFlow Corporation, the industry standard for flow benches, suggests 25 inches of water. The test pressure is read on a manometer attached to the bench while a rotary valve is controlled by the operator to arrive at this value. The aftermarket performance industry commonly flows at 28 inches of water, yielding higher flow numbers from the same port. A port that flows 200 cfm at 25 inches of water will now flow 212 cfm at 28 inches. Shops that have smaller or older flow equipment may not have the capacity in cfm to move a sufficient air volume to create higher test pressures. This style of equipment is usually operated at 10 inches of water. The results can be converted to any value with the chart provided in this text.
When discussing flow numbers for a potential porting job or the purchase of a set of heads, always identify the bore size used along with the test pressure, or you may not get what you paid for.
Before starting the procedure a leak test needs to be performed. This is done with both valves closed. There should be no leakage. If leakage is present in any area it should be corrected or the amount of leakage needs to be subtracted from the test data. To get the most benefit from flow testing it needs to be realized that either valve spends more time traversing the lift range than dwelling at maximum lift. Herein lies the fallacy of most published flow numbers, i.e., that they are at maximum lift and may also be at lift values higher than your cam will generate. A port is considered stalled when increased valve lift yields little or no increase in air volume, or an actual decrease. Low valve lift flow is critical for power production and a head that has better low lift numbers in most cases will outperform one with superior high-lift results. The recommended procedure is to calculate the test heights with an equation that takes the valve diameter and then multiplies it by a factor to determine seven test points.
The equation is: Net Valve Area =0.785 (valve diameter2-stem diameter2).
Once this is derived, it's multiplied by the Lift/Diameter (L/D) equation of .05, .10, .15, .20, .25, .30, .35, to determine the specified lift points for testing. This is done to make an accurate comparison of flow for different valve sizes in the same head. It is an acceptable practice for an experienced operator to flow at .050-inch lift graduations and not do the (L/D) calculations. L/D calculations are necessary when comparing the flow results of different size valves since they can be further broken down into valve efficiency, which represents cfm/square inch of valve area.
Whenever working with a flow bench to quantify changes to a port as it is being modified, it is essential to make your procedure as repeatable as possible. Dowel-pinned adapters are recommended for repeatability in positioning the cylinder head. Accurate valve opening fixtures that are rigid to avoid defection will ensure that the test data is accurate. Inaccurate flow data is worse than no data at all.
Ancillary tools that are used with the flow bench are velocity probes and threaded wands and steel balls on a welding rod. A velocity probe is used to measure the speed of the intake or exhaust port flow while the head is being tested. Using an additional manometer that's attached to the bench, velocity in feet/second can be derived. If the air is traveling too fast around the short-turn radius, it will shear or skid, reducing the effective valve area and choking flow. In most intake port designs, a threshold of 350 feet/second is the maximum speed for the air to follow the contour of the port. It must be remembered that when checking velocity on intake ports, the dynamics of inertia supercharging cannot be duplicated. Subsequently, exhaust port velocities do not calculate the thermal expansion and contraction from heating and cooling that occurs during blow-down and the pumping loop.
Threaded wand probes can be inserted in the port to visually display the movement of the air. Steel balls attached to welding rods are used along with clay to change the configuration of the port easily and temporarily to determine the effect on flow. Additional information can be quantified with the use of a swirl or tumble meter. In-cylinder charge motion can be documented with this equipment when attached under the bore adapter. Charge motion needs to be evaluated when developing a port since it has an effect on combustion.Recording the test results is just as important as performing an accurate test. Each operator has his or her own method of data recording. It varies from lift points and flow values handwritten on a piece of paper to advanced computerized data recording with Audie Technology Flow Pro software. All too often, a flow bench operator does not recognize the value in port mapping, valve area efficiency and graphing the port's performance. The Flow Pro software not only allows the operator to view all of this data and graphs easily, it becomes a learning tool for the head porter
The flow Test
Re: Making Sense of Cylinder Head Flow Testing
That article sounds like some of the official published material, such as an introduction, from either SuperFlow or Audie Tech. Anyway, I don't test with exhaust pipes on the exhaust side, and I'd say about 50% or more of the shops don't. My heartburn is the shops that do test with an exhaust test pipe, and quote big numbers, but they don't tell you they were test pipe numbers. Test pipe numbers will always be about 25 to 30 cfm higher at the peak valve lifts. They are almost the same down low at .100" and .200" lift. Moral of the story, to the potential buying customer,,,,,,always ask if the exhaust flow numbers were with a pipe or not.
Uncle Charlie
Uncle Charlie
c.evans- BBF VENDOR SPONSOR
very good info Charlie
Thanks for te info Mr. Charlie
Old blue Racin Team- Posts : 1579
While it is true that you do get larger flow #'s with a test pipe , I wouldn't say it's a "buyer beware" situation. Doing a comparison from shop to shop using different head porters who may use different test pipe set ups ( lengths,bends,diffusers,etc) which would vary the #'s & make the comparisons kind of pointless IMO. But if you don't flow test with test pipes, how do you find out what the port likes? We don't race cars w/o headers & they are extensions of the exhaust ports. David & Ron Sykes of Sykes Bros. Cylinder Heads put a lot of time & effort in my A429 CJ heads exhaust ports & yes they flowed them with a test pipe. But this allowed them to tell me how the headers needed to be built. We supplied VPRC with exact dimenions for how we wanted the headers built. I even took one of my headers & they flowed the head with header on it. The Sykes Bros. were very pleased with what they saw. I have to give kudos to Gary Naughton who built the headers. Another example are my C&C Boss 9 heads. The Sykes Bros. did some extensive flow testing with header flanges,different pipes & other ideas & found a huge improvement in flow. If they hadn't of done this, we would be building the headers in a traditional manor & left a ton of exaust flow on the table. So I guess it is the porter's preference on using them or not. I asked David Sykes a cylinder head question once & he gave me an answer. Then he added that if I asked that same question to 10 different head ports that I could possibly get 10 different answers & none of them would be wrong. So let the discussions begin.........
DISCLAIMER : This is not attacking anyone's ideas. It is just another point of view for discussion.
TopSportsman916- Posts : 36
Good post Chris, and you bring up some valid points.
I don't want anyone to get the idea that we haven't done our fair share of header /header primary pipe testing, because we have.
This is what I think I have learned.
1. The primary pipe size that flows the best on the flow bench, generally seems to be one size bigger, than the primary pipe size that makes the best power and torque on the dyno. Why? I think it's because the flow bench can't measure a headers ability to scavenge, the dyno can.
2. In 2001 on one of Phillip's engines, the bigger diameter primary pipe (2.375") made about 4 or 5 peak horsepower more than the one that was (2.250"), but it was down on torque by about 27 lbs.ft. as compared to the smaller header on the dyno. Which one did we choose, you guessed it. We've tested headers a lot since then too. As many of you know, I make a set of adapters for the OEM style Ford heads, that allows you to bolt on BB Chevy headers. We use those adapters a lot on the dyno, because different BB Chevy headers are so much more readily available, than Ford headers. It's like having a bigger assortment of carbs to test.
3. As a sidenote, I own four different sets of headers for Kristina's dragster. There are different diameter primary pipe, different length primary pipes, stepped headers, 4 into 1 collectors, merge collectors and you get the idea. Three of those sets are from our fellow racer and forum member Tim Murphy at the FabShop in Indy. I think the headers must work in conjunction with the convertor (in terms of torque peak and stall), and the dragstrip is one of the best places to test them,,,,with the e.t. slip.
Hope this helps,
Uncle Charlie
Hope this helps,
Uncle Charlie
Charlie, thanks for expanding on your original post. Some good info there..
" In 2001 on one of Phillip's engines, the bigger diameter primary pipe (2.375") made about 4 or 5 peak horsepower more than the one that was (2.250"), but it was down on torque by about 27 lbs.ft. as compared to the smaller header on the dyno"
I am/was of the opinion that the lost of tq. with the 2.375" primary headers was as much [maybe more] about the lenght of the primary pipes .
Nick: What does it matter, you know that your max ported Edelbrocks RULE!
Gary
Gary
GTmustang- BBF CONTRIBUTOR
Lem Evans wrote:" In 2001 on one of Phillip's engines, the bigger diameter primary pipe (2.375") made about 4 or 5 peak horsepower more than the one that was (2.250"), but it was down on torque by about 27 lbs.ft. as compared to the smaller header on the dyno"
Lem,
I really think you are right, so I stand corrected.
Thanks,
Charlie
Something I have always wondered about:
On a flow bench the valve is static and the airflow is constant. When on an engine, the valve is opening and closing rapidly and the air column is starting/stopping rapidly. I know a flow bench can't duplicate this but a dyno can.
Is there certain things in a port that will work good on the flow bench with a constant flow but really screw things up (sorry for the technical speak!!!) on a running engine?
Bill
Bill
billandlori- Posts : 2081
very good point Bill ...
Bill,
IMO, and like what Chris said earlier, you'll get 10 different answers,,,,,, I think you need to guard against opening the throat/choke up too much in diameter in relationship to the valve diameter, because the engines don't seem to accelerate as well. Also, I think you need to be careful not to make the port too big, because quite often you'll lose port velocity, and again the engines don't seem to accelerate as well.
Hope this helps,
Charlie
Hope this helps,
Charlie
Thanks Charlie.
I guess the larger the volume of air sitting at the valve (large port volume) takes longer to get moving. Air has mass and takes time to get moving and stop, but its also elastic and can be stretched and compressed.
Its quite an art and I'm sure there is a ton of compromizes need to be made over the RPM range. I think its cool how the port size/shape doesn't just effect peak HP/TQ but also how the engine accelerates. Quite interesting.
Bill
Bill
» NDT Testing on a ford cylinder head
» Cylinder Head Flow Thread
» cylinder head flow vs cam lift
» Cylinder Head Flow Reference Chart
» Trick flow a460 cylinder head sale
