New best ET
nuclearcobra
New best ET
I went a few Fridays ago to a TNT finally after dropping a valve last May and cracking a guide boss in the scj head , I figured its time to put it back together so i did and i tried a nitrous converter that i got from 10 Shots when i got the trans from him a few years back. Anyway i sent the converter to Lenny at Ultimate to change it for my 70 crank with the 1.850 pilot recess and do some upgrades he says , The converter that was in it i bought for $300 from here to get it up and running and it was so consistent i left it in there , It was a Hughs 4000 i was told and i went a best of 9.95 leaving at 2000-2500 which at 2500 it would normally push through , best 1/8 was 6.30 once in the cold , I did spray a 150 shot doing license runs with this combo and it ran 6.13 at 111mph in the 1/8th , and later tried a 180 shot and ran a 5.96 , Well Friday with this different converter i ran 6.12 at 112mph all Motor with a 1.35 60' leaving at 2500 on the foot brake I was floored , i knew the old converter wasn't right for my combo but i never thought it was that far off , Well they called lanes close in 15 so i said what the heck let me try a 150 shot again with this new converter and i thought i was floored before well we got the pressure up to 900 which i usually have it at a 1000' but ran out of time and headed to the lanes , So i let it rip and it had a spinning 1.36 60' and ran a 5.82 at 119 mph plus in the 1/8th , I did find out Saturday morning how lucky i got not destroying this motor as i never hooked up the fuel solenoid line to my fuel line much less it being a vacuum leak when it opened , Never hurt a plug or anything. So now i wonder what a 150 with fuel will do , The jetting is 62n-56f with 6 degrees timing out from 30 total and 6-1/2lb fuel pressure , well that's what my carb is at and i just hook up to where my fuel pressure gauge port is on the line going to my back bowl. I know its cheesy but i just ordered a pump and regulator from IS two days ago and have a front cell that came in my car when i got it. All in all I'm tickled so far Its a 472, diamond flat tops , scj heads and 4150 victor intake unported,HP 950 carb 80-90 jets, flat tappet solid cam , Its a 84 mustang 2750lb with me , c6 ,28x10 slick, 8.8 with 3.90's Foot Braking , I've yet to try a trans brake but it has one in it. My goal from the get go with this combo was to see if its possible to get it in the high 8's with N2o with a simple combo , non stroker , box stock heads ,flat cam and flat tops. Had a lot of nay Sayers along the way tho from it wont happen with that compression , or without a roller cam in there , or unported heads , bla bla bla , well i think I,m close now , I'll have to use the 1/8 mile time as the 3.90's wont make it to the 1/4 plus i'm taking a real liking to this 1/8 mile stuff now that I've tried it which i was so against forever. , I just put new slicks on and wont forget to hook up that fuel line again and pressure will be 1000 this time.
nuclearcobra- BBF CONTRIBUTOR
Re: New best ET
nuclearcobra wrote:I went a few Fridays ago to a TNT finally after dropping a valve last May and cracking a guide boss in the scj head , I figured its time to put it back together so i did and i tried a nitrous converter that i got from 10 Shots when i got the trans from him a few years back. Anyway i sent the converter to Lenny at Ultimate to change it for my 70 crank with the 1.850 pilot recess and do some upgrades he says , The converter that was in it i bought for $300 from here to get it up and running and it was so consistent i left it in there , It was a Hughs 4000 i was told and i went a best of 9.95 leaving at 2000-2500 which at 2500 it would normally push through , best 1/8 was 6.30 once in the cold , I did spray a 150 shot doing license runs with this combo and it ran 6.13 at 111mph in the 1/8th , and later tried a 180 shot and ran a 5.96 , Well Friday with this different converter i ran 6.12 at 112mph all Motor with a 1.35 60' leaving at 2500 on the foot brake I was floored , i knew the old converter wasn't right for my combo but i never thought it was that far off , Well they called lanes close in 15 so i said what the heck let me try a 150 shot again with this new converter and i thought i was floored before well we got the pressure up to 900 which i usually have it at a 1000' but ran out of time and headed to the lanes , So i let it rip and it had a spinning 1.36 60' and ran a 5.82 at 119 mph plus in the 1/8th , I did find out Saturday morning how lucky i got not destroying this motor as i never hooked up the fuel solenoid line to my fuel line much less it being a vacuum leak when it opened , Never hurt a plug or anything. So now i wonder what a 150 with fuel will do , The jetting is 62n-56f with 6 degrees timing out from 30 total and 6-1/2lb fuel pressure , well that's what my carb is at and i just hook up to where my fuel pressure gauge port is on the line going to my back bowl. I know its cheesy but i just ordered a pump and regulator from IS two days ago and have a front cell that came in my car when i got it. All in all I'm tickled so far Its a 472, diamond flat tops , scj heads and 4150 victor intake unported,HP 950 carb 80-90 jets, flat tappet solid cam , Its a 84 mustang 2750lb with me , c6 ,28x10 slick, 8.8 with 3.90's Foot Braking , I've yet to try a trans brake but it has one in it. My goal from the get go with this combo was to see if its possible to get it in the high 8's with N2o with a simple combo , non stroker , box stock heads ,flat cam and flat tops. Had a lot of nay Sayers along the way tho from it wont happen with that compression , or without a roller cam in there , or unported heads , bla bla bla , well i think I,m close now , I'll have to use the 1/8 mile time as the 3.90's wont make it to the 1/4 plus i'm taking a real liking to this 1/8 mile stuff now that I've tried it which i was so against forever. , I just put new slicks on and wont forget to hook up that fuel line again and pressure will be 1000 this time.
Congrats I seen your nervous post on YB in the Nitrous section!!!!
Mark Miller- Posts : 1958
Re: New best ET
Oh yeah!! With the fuel line hooked up and everything set, I don't see why you would not get that 8 second time slip!!
Of course ported heads and intake, and a nice roller cam would get it there a little easier, but I think you are about to get what you are after, even without those things!!
Please keep us posted on your progress!!
BBFTorino- Posts : 999
Re: New best ET
good numbers CONGRATS!!!! 2 questions....
1. did you learn anything about nitrous ?
2. how well does the 460 fit in the mustang II ? does it still have stock front suspension ?
wayne
wayne
wayney- Posts : 187
Re: New best ET
wayney wrote:good numbers CONGRATS!!!! 2 questions....
wayne
He has the 460 in a 84 Mustang,IIRC he has a 302 with Nitrous in the MustangII!!!
Re: New best ET
Yes the 76 mustang has a 302 the 84 has the 460 , Both have N2o
IMG_2198 by Nuclearcobra, on Flickr
IMG_2195 by Nuclearcobra, on Flickr
IMG_2200 by Nuclearcobra, on Flickr
Re: New best ET
ok, I wondered about how or if a 460 would fit in mustang II.
how about question 1 ?
wayney- Posts : 187
Re: New best ET
Yes they stuff them in mustang 2's , I just wanna put a windsor stroker in it with my kaase canted valve heads I have a nice windsor 396 kit i got years ago from a Good Ole Southern Georgia Motorhead named Mike , I've only had 302's in it so far and its been 5 years for one of those , I actually started on it now that my yellow car is going , I want it registered again to take cruises like old times , Had that car since 94 it was a fun little 10 second street car and does big wheel stands to boot And no i doubt i learned anything , I have learned in the past to not rush hooking up N2o , especially after a year of not touching the car at all , I've learned to not F around with a bottle to show off in front of your friends while being drunk as it lands you in the ER with a fat bill , I've learned to never trust the markings on your new damper and to mark TDC yourself because Nitrous melts cylinder heads too not just pistons and plugs
Re: New best ET
I was referring to the theories everybody talks about that when you lean nitrous out you kill engines. Long time ago(about 1993) I experienced this first hand. Car had one fuel pump for the dominator and fogger system combined. Launched the car at the track , keys in console flew back and turned the toggle switch for the fuel pump off. car ran full throttle with the nitrous on (40 jet in the fogger) untill the float bowels ran out of fuel and motor quit running. never hurt anything in the motor. no burned pistons, no blown head gasket nothing. I like my tunes a little lean.
wayne
wayne
wayney- Posts : 187
Re: New best ET
Good numbers. Shows again how critical the converter is to the combination. On the 460 in a MII - most I've seen required heavy front end work and moving the frame rails 4" farther apart. Or a complete strut fab from scratch. A 302 is tight in those cars and a super tight trans tunnel. Stock flexplate is only 148 tooth IIRC.
Falcon67- Posts : 15
suspension setup
What for suspension setup are you running? I'm having a very difficult time getting mine to hook every time. Then again I am running a 275 radial tho. My combo is a little more stout and I have an IS System i'm currently installing. My setup is a 533 w/ AFR heads, solid roller, 1050 dominator. The best ET so far has been 9.24@143 N/A. My '87 coupe wheel stands like a mofo when it hooks. I run a 3.75 gear. I plan on running a 150 or so shot on mine once I get it figured out. I'm thinking it should go 8.70's on a mild tune. I'm not sure if I wanna throw a 250-300 shot to this or not.
bpmustang- Posts : 20
Re: New best ET
Even smaller its 141 tooth.Falcon67 wrote:Good numbers. Shows again how critical the converter is to the combination. On the 460 in a MII - most I've seen required heavy front end work and moving the frame rails 4" farther apart. Or a complete strut fab from scratch. A 302 is tight in those cars and a super tight trans tunnel. Stock flexplate is only 148 tooth IIRC.
Re: New best ET
Its homemade ladder bars , arb , lakewood 50/50 shocks , Dodge Omni 4 cylinder springs with air bags with stock uppers and lowers.bpmustang wrote:What for suspension setup are you running? I'm having a very difficult time getting mine to hook every time. Then again I am running a 275 radial tho. My combo is a little more stout and I have an IS System i'm currently installing. My setup is a 533 w/ AFR heads, solid roller, 1050 dominator. The best ET so far has been 9.24@143 N/A. My '87 coupe wheel stands like a mofo when it hooks. I run a 3.75 gear. I plan on running a 150 or so shot on mine once I get it figured out. I'm thinking it should go 8.70's on a mild tune. I'm not sure if I wanna throw a 250-300 shot to this or not.
Team Z anti roll bar 004 by Nuclearcobra, on Flickr
