4150 to 4500 adapter
4150 to 4500 adapter  Empty 4150 to 4500 adapter
Post  nuclearcobra May 20th 2018, 10:36 pm
I'm getting ready to try a dominator for the first time , I have two types of adapter plates to use , one is the 4 hole aluminum 2'' super sucker and the other is a moroso open spacer that's 2 inch also. Is one of the two a better choice ? The carb is a 1090 Demon and intake is the 429 G.
nuclearcobra
nuclearcobra
4150 to 4500 adapter  Empty Re: 4150 to 4500 adapter
Post  BBFTorino May 21st 2018, 1:46 am
What RPM range will you be running it at??
Post  pmrphil May 21st 2018, 8:14 am
I prefer the super sucker - they normally increase airflow, and with that should increase torque.
pmrphil
Post  nuclearcobra May 21st 2018, 10:31 pm
BBFTorino wrote:What RPM range will you be running it at??
Foot brake 2500 shift at 6700
nuclearcobra
nuclearcobra
Post  nuclearcobra May 23rd 2018, 8:37 am
If it likes it I'll try the mafia intake I've had for years , I kinda been saving it for when i get the heads ported and finally try a roller cam for the first time ever in anything. Always did flat tappet deals.
nuclearcobra
nuclearcobra
Post  BBFTorino May 24th 2018, 1:25 am
Try both spacers if you can, but I think the 4 hole spacer may help make a little more torque in the mid range.
Post  nuclearcobra May 24th 2018, 1:45 pm
I will try both , I think i read before with the super sucker you need to jet down some so you don't run rich because they will pull more fuel.
nuclearcobra
nuclearcobra
Post  IDT-572 May 25th 2018, 9:44 am
The Dominator may stumble on a foot brake deal unless you can hold it fairly high in the rpm range on the leave, If it does the super sucker should help that problem.
Post  nuclearcobra May 25th 2018, 5:00 pm
Yea Lem , Charlie , AED and a few others said i need a dominator on it but not with my footbrake converter because of the stumble , so i stuck with the hp 950 for now with 80-90 jets and pv. I finally put a different converter in which is a nos converter i got with my C6 from 10shots , I had Lenny go through it and change the crank pilot snub to a 1.850 so i could try it , I was shocked it ran faster all motor than it did with a 150 shot using the old converter , I knew the old converter wasn't right for my combo but i never thought it was that far off. I ran 6.135 with a 1.342 60' at 111.74 mph with a 150 shot and on motor with the new converter it ran 6.120 at 112.26 with a 1.353 60' , So that same night the 4th and final pass i tried the same 150 shot again but never hooked up the fuel side of the plate and it ran 5.82 at 119 plus mph , I was shocked and more shocked the next morning when i noticed i forgot to run the fuel line to the solenoid. And happy i didn't hurt even a single plug.
nuclearcobra
nuclearcobra
Post  IDT-572 May 29th 2018, 9:11 am
That makes me think it's fat on the engine tune.............
Post  pmrphil May 29th 2018, 12:29 pm
I would agree that it's fat, didn't that carb come with 78's and 2 power valves?
pmrphil
Post  supervel45 May 30th 2018, 12:36 am
Is it the old HP 950, that is closer to a 830 in the real world, List Number 80496-1? If so the Holley book shows 79 jets front and rear with dual 6.5 hg" power valves. You might be a tad fat if you blocked the rear PV and put 90's in but not that far off from stock jetting.
Post  supervel45 May 30th 2018, 12:41 am
nuclearcobra wrote:Yea Lem , Charlie , AED and a few others said i need a dominator on it but not with my footbrake converter because of the stumble , so i stuck with the hp 950 for now with 80-90 jets and pv. I finally put a different converter in which is a nos converter i got with my C6 from 10shots , I had Lenny go through it and change the crank pilot snub to a 1.850 so i could try it , I was shocked it ran faster all motor than it did with a 150 shot using the old converter , I knew the old converter wasn't right for my combo but i never thought it was that far off. I ran 6.135 with a 1.342  60' at 111.74 mph with a 150 shot and on motor with the new converter it ran 6.120 at 112.26 with a 1.353  60' , So that same night the 4th and final pass i tried the same 150 shot again but never hooked up the fuel side of the plate and it ran 5.82 at 119 plus mph , I was shocked and more shocked the next morning when i noticed i forgot to run the fuel line to the solenoid. And happy i didn't hurt even a single plug.
I re-read that again, pretty wild. Was the bottle almost empty? Wink
Post  nuclearcobra May 30th 2018, 8:32 am
I built the 950 from scratch with a main body from AED , proform billet metering blocks and base plate , I was using a borrowed ported Hp 950 MOD from AED that flowed 1020 and that had 80-90 jets so i tried those jets in mine just to see how it would do and it ran fine , the plugs AR 3934 look light tan all season so i left those jets in there. I agree its on the fat side , It would run 10.0's with 9.95 at best on motor when its cool out and slow up to 10.10-15 in the heat , Steve Johnson got back to me as to how i didn't hurt anything and said he's seen this several times in the past , Bottom line no fuel no fire he said , Bottle was full. Timing was at 24 , its 30 degrees on motor. Engine was on the cold side from sitting in the lanes to long from a oil down so maybe all that helped.
nuclearcobra
nuclearcobra
