need help asap with crank trigger
making to switch from chain drive to the danny bee belt drive. everything is together and on but all i need to do now is mount the crank trigger (wheel is already on just the bracket with the sensor. its the same set up that was once on the car before the swap over, I bought/using a team z bbf motorplate for the belt drive i cant get the bracket to bolt up or close enough to the wheel where it needs to be without being in the way of the waterpump snout, using an electric pump, i have prictures of the set up before and after but dont know how to post, can send to someone if need too please help last i need to fire this one up lol
Rickytx630- Posts : 100
Re: need help asap with crank trigger
Rickytx630 wrote:making to switch from chain drive to the danny bee belt drive. everything is together and on but all i need to do now is mount the crank trigger (wheel is already on just the bracket with the sensor. its the same set up that was once on the car before the swap over, I bought/using a team z bbf motorplate for the belt drive i cant get the bracket to bolt up or close enough to the wheel where it needs to be without being in the way of the waterpump snout, using an electric pump, i have prictures of the set up before and after but dont know how to post, can send to someone if need too please help last i need to fire this one up lol
send the pic to me, keep in mind you can mount it on either side.
BOSS 429- Posts : 2372
» Looking to trade a BBF MSD crank trigger for a SBF crank trigger
» Crank trigger?
» 4.500 CRANK NEEDED ASAP
» Crank trigger and DIS
» Crank trigger?
