Kaase P51 Sheet Metal Valve Covers Question
I received a pair of new Kaase sheet metal valve covers with my engine project purchase. Currently they have no breather holes of any kind. As stated in a previous post, this will be a street engine build. What hardware do you use to add breathers/oil fill to these covers. Is there a preferred location? As pretty as they are it feels like a crime to put a hole in them. Thank you.
Athlonia- Posts : 21
Re: Kaase P51 Sheet Metal Valve Covers Question
Athlonia wrote:I received a pair of new Kaase sheet metal valve covers with my engine project purchase. Currently they have no breather holes of any kind. As stated in a previous post, this will be a street engine build. What hardware do you use to add breathers/oil fill to these covers. Is there a preferred location? As pretty as they are it feels like a crime to put a hole in them. Thank you.
Make sure it is between rocker arms, not over one.
And, as high near the intake manifold as you can safely get.
rmcomprandy wrote:Athlonia wrote:I received a pair of new Kaase sheet metal valve covers with my engine project purchase. Currently they have no breather holes of any kind. As stated in a previous post, this will be a street engine build. What hardware do you use to add breathers/oil fill to these covers. Is there a preferred location? As pretty as they are it feels like a crime to put a hole in them. Thank you.
Thank you! Do I need to worry about any baffling?
Athlonia wrote:rmcomprandy wrote:Athlonia wrote:I received a pair of new Kaase sheet metal valve covers with my engine project purchase. Currently they have no breather holes of any kind. As stated in a previous post, this will be a street engine build. What hardware do you use to add breathers/oil fill to these covers. Is there a preferred location? As pretty as they are it feels like a crime to put a hole in them. Thank you.
Maybe but, maybe not is all I can say for sure.
Stud girdle bars help that cause.
» Sheet metal Valve covers/Aluminum T bottom oil pan
» Moroso sheet metal valve covers SOLD
» Short Sheet Metal Valve Covers and Roller Camshafts
» WTB: used aluminum sheet metal valve covers to fit the original AR/Motorsport A441 hemi heads
» COMP Cams 841-16 Endure-X, Sheet metal valve cover, Ultra Pro Magnum roller rockers
