Cometic
Cometic
Well this is my first time using Cometic Head Gaskets on my 572 CID, TFS and M 6010 A460 block. The Cometic package lable reads "Ford 429/460CI 4.630 BORE...... .080 MLS-5 HEAD-STOCK BLOCK... I installed these on my block and some of the small water holes do not line up. You guys probably run into this stuff all the time.. Is this ok? I was using copper head gaskets on the original build and massaged them a little and had no leaks or issues..
Thx
Thx
747JetMech- Posts : 272
Re: Cometic
The first small hole next to the dowel on cyl # 1, I had to drill the block. 1/4"Ø
And from memory, # 5 as well.
hienergy557- Posts : 179
I contacted Cometic this morning and asked if I can drill their gasket out to match.. I have a early Motorsport Block and was wondering if that is why they are not lining up. It's not all the holes but just some of the small ones.. I figured Ford put the holes there for a reason so I will do my best to make sure they flow..
Thx
Thx
Gaskets
Hello,
I believe this is due to the gasket being a stock style 460 head gasket. You would need something for the A460. I would look into part number C5744-080
>>>>>>>>>>>>>>>>>>>>> That is what I received from Cometic.
To drill or not to drill.... HMMMMMMmmmm
Gasket number is H1771SPD080S
Last edited by 747JetMech on Wed 6 Jun 2018 - 22:30; edited 1 time in total (Reason for editing : additional info)
Re: Cometic
747JetMech wrote:Hello,
The Cometic gaskets I stock have my special part #......the steam holes are in the correct place......I had them moved.
Lem, If these fail, I will reorder the correct ones from you. Water flows from front to back on the block and back to front on heads? I will make sure at least the rear holes match up. Maybe take a small rotary tool and open up the steam holes. Need to make sure that I get any burrs out between layers and any debris removed. What a pain...
Re: Cometic
747JetMech wrote:Lem, If these fail, I will reorder the correct ones from you. Water flows from front to back on the block and back to front on heads? I will make sure at least the rear holes match up. Maybe take a small rotary tool and open up the steam holes. Need to make sure that I get any burrs out between layers and any debris removed. What a pain...
Relax, it'll be okay.
» I got my cometic gaskets now what???
» cometic gaskets
» cometic head gasket
» COPPER HEAD GASKETS
» cometic mls gaskets
» cometic gaskets
