older style msd crank trigger question
got the car ready to fire up and when i went to put the crank trigger sensor in i notice it was cracked near the wires and looks like it rubbed at one point against the wheel, my question is im looking to buy a new sensor but not sure which one to get, i noticed on msd's site that they offer an older style universal sensor, its at least 15 years old so im guessing thats what i need but i want to double check, its a bbf set obviously, been having some problems yesterday and today, was hoping this is the issue,
Rickytx630- Posts : 100
Re: older style msd crank trigger question
ohm test it, its either good or not.
rubbin the wheel has never seem to hurt them
BOSS 429- Posts : 2372
New style wheel has magnets, old style does not.
bosshoss- BBF CONTRIBUTOR
crank tigger
so now that i got the new sensor and the points on the cam and crank pullys line up, with number one at tdc, and the rotor facing number one on the cap the dizy drop right in, but with that ot still pops threw the exhaust and wont fire, even haad the balamcer at 30* and it does the same thing, the car was under the awning withcar over for 2 days, one being that it rained and i had 3 plastic bags covering the box, what are the changes the box is no good? its a 7al3 (red old style) car is a t-top car and the floor near the rr tub was a little wet but that was it,
most likely 180 degrees off - with the timing dots pointing at each other I believe it's on the exhaust stroke. If it popped at all it's still making spark.
pmrphil- Posts : 171
Rickytx630 wrote:so now that i got the new sensor and the points on the cam and crank pullys line up, with number one at tdc, and the rotor facing number one on the cap the dizy drop right in, but with that ot still pops threw the exhaust and wont fire, even haad the balamcer at 30* and it does the same thing, the car was under the awning withcar over for 2 days, one being that it rained and i had 3 plastic bags covering the box, what are the changes the box is no good? its a 7al3 (red old style) car is a t-top car and the floor near the rr tub was a little wet but that was it,
call me
» Crank trigger and DIS
» Crank Trigger and Timing Pointer Question
» Looking to trade a BBF MSD crank trigger for a SBF crank trigger
» aluminum crank pulley and a crank trigger
