ZF bolt pattern?
ZF bolt pattern?  Empty ZF bolt pattern?
Post  blown473 June 16th 2018, 3:21 pm
Is it true that the ZF 5 speed from behind Ford diesels is the same block bolt pattern as 460's just the bolt holes are larger ? Saw this posted on another site, never heard this not sure if true, seems you could just bushing the holes down if it was or just find a 460 ZF.
blown473
blown473
ZF bolt pattern?  Empty Re: ZF bolt pattern?
Post  fordmonsta July 16th 2019, 10:33 am
No they are different
fordmonsta
ZF bolt pattern?  Empty ZF bolt pattern.
Post  blown473 July 17th 2019, 8:05 pm
Thank you for that info, myth solved !
blown473
blown473
Post  greaser302 January 22nd 2020, 3:27 pm
They are the same, 2 holes need to be enlarged, you need to drill starter holes into the diesel bell housing. It will bolt up after the mods.
greaser302
