Motorplate as transmission adapter
Hello, I was wondering if anyone has used a mid motor plate as a bellhousing adapter to use a different transmission. I'm looking to use a small block housing with a multi plate clutch to save room and be able to push engine further back in the build. Would a 1/4 steel plate or closer to a 1/2 inch aluminum plate make it as a viable adapter. Or am I just reinventing the wheel with a big chance of failure. Thanks for any help.
Seth
Seth
litshoot- Posts : 103
Re: Motorplate as transmission adapter
I had a PG adapter for my old Cleveland that was 1/2inch aluminum. Worked good, needed a spacer on the back of the crank to make the torque converter nose fit.
bosshoss- BBF CONTRIBUTOR
litshoot wrote:Hello, I was wondering if anyone has used a mid motor plate as a bellhousing adapter to use a different transmission. I'm looking to use a small block housing with a multi plate clutch to save room and be able to push engine further back in the build. Would a 1/4 steel plate or closer to a 1/2 inch aluminum plate make it as a viable adapter. Or am I just reinventing the wheel with a big chance of failure. Thanks for any help.
Seth
That's how it's done.
Curt- Posts : 2791
Curt wrote:That's how it's done.
Nice. Any pointers for how to best align it all. Figured, mark a template from the old transmission, align it to the block then align new transmission and mark holes for new bell,installing clutch and pilot bearing should give me the best chance of correct alignment. Can I just tap the plate and get appropriate length bolts threaded into them?
litshoot wrote:Curt wrote:That's how it's done.
Just have Keith Fulp make you one. It will probably be cheaper than trying to do one yourself. One mistake will be costly. Click here for Keith Fulp Motorsports
Curt- Posts : 2791
Curt, While looking into this all last night I actually emailed him fairly late last night 630 this morning I had a response saying he will look into this
my other questions being I got to looking last night the rails spread out wider, perhaps an additional crossmember with risers to attach the plate to might be an option. its nearly 4 foot between the rear part of the rails, the brake booster is more inboard than the frame rail. might need some inventive fixes. Others wise no midplate using only a front and trans mount.
The mid plate can be as wide as needed and skeletonized if you need clearance for headers, brake boosters etc. I had a mid plate in a SG car years ago that only fastened at the very top to the cross bar with two 3/8" fasteners.
Curt- Posts : 2791
» WTB Small block eo4d to 460 transmission adapter
» Question regarding SFI bellhousing for auto transmission, and Automatic Transmission Flexplate Shield
» another motorplate cut
» 429/460 parts ( soild roller lifters and motor plate)
» home made front plate
