going from c6 to glide
bosshoss
Rickytx630
going from c6 to glide Empty going from c6 to glide
Post  Rickytx630 August 12th 2018, 12:47 pm
after thinking it over, i came to a decision that im gonna be replacing the ole c6 for a glide, notihng wrong just time to free up a little more hp, what should i look for and what would i need? whos casing or trans for i go with, how many runs between rebuilds etc?
Rickytx630
going from c6 to glide Empty Re: going from c6 to glide
Post  bosshoss August 12th 2018, 9:12 pm
cant beat the reid case and adapter bellhousing...
how much hp you putting through it?
bosshoss
bosshoss
Post  whitefield August 12th 2018, 9:35 pm
How much hp do you think it will free up ?
whitefield
whitefield
Post  Rickytx630 August 18th 2018, 2:56 pm
im not sure on the exact hp on the motor, car weighs 3022lbs with me race ready, car run 8.8x in the quarter, and back half, 4.10 reargear 33x16 mt tire on a 15x15 rim. single 4bbl
Rickytx630
Post  Rickytx630 August 18th 2018, 2:57 pm
its a n/a set up 514
Rickytx630
Post  whitefield August 18th 2018, 8:21 pm
Rickytx630 wrote:im not sure on the exact hp on the motor, car weighs 3022lbs with me race ready, car run 8.8x in the quarter, and back half, 4.10 reargear 33x16 mt tire on a 15x15 rim. single 4bbl
I run mostly 1/8 mile so what is your 1/8 mile and 60 ft time with the c6 and current set up ? What stall speed are you running? I am curious as to what the difference will be ?
whitefield
whitefield
Post  Rickytx630 September 3rd 2018, 3:11 pm
sorry been a little since i been on, had to get a new laptop lol, always 1/8 mile times on the 7 passes ive made so far have been between 5.53 ( best so far) and 5.58, mph 122-124
Rickytx630
Post  Rickytx630 September 3rd 2018, 3:16 pm
60' usually in the 1.25, ive had a best of 1.22 but bailed on the run at half track as i went red, track temp was at 112*
Rickytx630
Post  jbozzelle September 3rd 2018, 9:41 pm
All ATI Supercase and adapter bell combo in mine.  Using one of Keith Fulp's .100 thick mid/locator plates, JW Wheel and a PTC converter...
Post  Rickytx630 September 3rd 2018, 11:34 pm
jbozzelle wrote:All ATI Supercase and adapter bell combo in mine.  Using one of Keith Fulp's .100 thick mid/locator plates, JW Wheel and a PTC converter...
i been looking around all day, kinda confused, i know most use the adapter plate for the flexplate which is fine, however if using a ford housing is the adapter still needed? the car currently doesnt have a midplate in it, however im leaning towards a chassis over the winter for it, now with that said and i were to use the midplate, whats done to starter for it can reach? is the midplate area cleared so it fits in the normal holes in the bellhousing?
Rickytx630
Post  bosshoss September 4th 2018, 3:07 am
easiest way is to have the mid plate made to the same pattern as the stock block plate. Then the starter/flex plate relationship doesn't change...
Depending on the thickness of the midplate you may have to either shim the converter, and or possibly extend the nose.
I also have a Keith Fulp designed mid plate in mine with the Reid adapter bell. and the Meziere flex.
When I ran the JW stuff they would send a little steel adapter for the back of the crank to mate up with the Chevy converter snout..
I could never keep them tight in the crank so I ended up making my own.
bosshoss
bosshoss
Post  johndickjr January 22nd 2019, 1:18 pm
bosshoss wrote:easiest way is to have the mid plate made to the same pattern as the stock block plate. Then the starter/flex plate relationship doesn't change...
how can that be? the starter bolts to the tranny so if it is moved back .100tho the starter has to move with it
johndickjr
Post  bosshoss January 22nd 2019, 1:23 pm
mid plate is made same pattern as stock block plate so it fits between the starter and the tranny...
dkp
bosshoss
bosshoss
Post  johndickjr January 22nd 2019, 2:39 pm
bosshoss wrote:mid plate is made same pattern as stock block plate so it fits between the starter and the tranny...
dkp
I know but they are bolted together , so both will move say .100, that throws off the starter to flex plate spacing unless you shim out the flexplate too or am I missing something
johndickjr
Post  cool40 January 22nd 2019, 11:03 pm
dkp
no,the plate could be 3" thick and it wouldn't matter. the starter sets on the front side of the plate so it don't know how thick the plate is.
Post  johndickjr January 23rd 2019, 7:32 am
cool40 wrote:
dkp
im a dork, after I looked at mine I see what you mean
johndickjr
Post  cool40 January 23rd 2019, 11:47 am
It’s easy to get confused. All the mid plate thickness affects is the converter spacing.
