Oil restricter
Oil restricter  Empty Oil restricter
Post  69F100 September 22nd 2018, 10:10 am
What is needed to restrict some oil from the lifters after I changed rocker arms I got to much oil to top half. I am not loosing oil pressure now after a run with the new pan but my vacuum pump sucking oil out of the valve cover. I have a baffles in the valve covers. I don't have any blow bye with vacuum pump off so I don't think it is the rings the engine only has maybe 20 passes on it.
Oil restricter  Empty Re: Oil restricter
Post  Lem Evans September 22nd 2018, 10:35 am
loosing pressure on the gas or off the gas with brakes on?
Post  rmcomprandy September 22nd 2018, 8:44 pm
69F100 wrote:What is needed to restrict some oil from the lifters after I changed rocker arms I got to much oil to top half. I am not loosing oil pressure now after a run with the new pan but my vacuum pump sucking oil out of the valve cover. I have a baffles in the valve covers. I don't have any blow bye with vacuum pump off so I don't think it is the rings the engine only has maybe 20 passes on it.
What you should use depends upon whatever block you have.
Post  dfree383 September 22nd 2018, 9:13 pm
Pushrods would be easy
Post  69F100 September 23rd 2018, 5:57 am
Running a D9 block I haven't seen a drop in oil pressure after putting the new oil pan on. Before it was at the end of the run when i would get on the brakes. Never had that problem until I changed my rocker arms and went to the Crane Gold rocker.
Post  rmcomprandy September 23rd 2018, 9:33 am
69F100 wrote:Running a D9 block I haven't seen a drop in oil pressure after putting the new oil pan on. Before it was at the end of the run when i would get on the brakes. Never had that problem until I changed my rocker arms and went to the Crane Gold rocker.
Like Dave said ... restricted pushrods is your only alternative with a production oiling system; (unless bushing the passenger side lifter bores).
Post  69F100 September 23rd 2018, 12:02 pm
Thanks for the info I will check on new push rods with restricter in them I have to pull a intake and exhaust can't remember the length of of them off the top of my head
Post  BOSS 429 September 23rd 2018, 10:51 pm
I kn ow of 4 or 5 guys in the last 2 years same prob with the crane golds, no so much a prob if you install restrictors, or like was said pushrods.
the crane rocker at lift line up the oil holes better them some other rockers,thus letting more oil by
Post  69F100 September 24th 2018, 10:23 pm
I am running right now .080 wall going to stop by Summit tomorrow on the way home and pickup some .135 wall pushrods . I was thinking the .135 would have a smaller oil hole that would restrict the oil. I called Summit and ask them about oil restrictor pushrods in a 3/8'' 8.55 and 8.65 said he did not have a listing for oil restrictor pushrod that size only ones he showed was in 5/16''. Am I right .135 would have a smaller hole by the math it should be .055 smaller hole than the .080 if so I get them and try.
Post  rmcomprandy September 25th 2018, 9:15 am
69F100 wrote:I am running right now .080 wall going to stop by Summit tomorrow on the way home and pickup some .135 wall pushrods . I was thinking the .135 would have a smaller oil hole that would restrict the oil. I called Summit and ask them about oil restrictor pushrods in a 3/8'' 8.55 and 8.65 said he did not have a listing for oil restrictor pushrod that size only ones he showed was in 5/16''. Am I right .135 would have a smaller hole by the math it should be .055 smaller hole than the .080 if so I get them and try.
They are no restriction at all ... you will need pushrods which are designated "Restricted" which have only about a .020" hole in the lifter end.
Call a pushrod manufacturer, not Summit.
Post  dfree383 September 25th 2018, 9:59 am
Manton, Trend and smith brothers are all high quality manufactures of custom pushrods
Post  BOSS 429 September 25th 2018, 1:25 pm
smith bros push rods
Post  69F100 September 25th 2018, 4:13 pm
dfree383 wrote:Manton, Trend and smith brothers are all high quality manufactures of custom pushrods
Called Smith Brothers and ordered 8 8.550 and 8 8.650 restrictor pushrods for $200 plus shipping that less than what I payed for the ones I got in it now.
Post  69F100 September 25th 2018, 7:53 pm
Called Smith Brothers and ordered 8 8.550 and 8 8.650 restrictor pushrods for $247 plus shipping that less than what I payed for the ones I got in it now.
Post  69F100 September 25th 2018, 7:55 pm
it was $247 plus shipping not $200
