expansion tank water pump
expansion tank water pump Empty expansion tank water pump
Post  kjett October 4th 2018, 9:02 am
running an alcohol injection setup on my new truck and not planning to run a radiator since it should only be running 3-4 seconds at a time. Plan is to just run a short shose set up to and aluminum U bend to circulate some water to cool the heads after the nitrous passes. did some searching and can't find/remember who made the electric expansion tank style water pumps to give me a way to fill the system a little easier. Anyone know who makes them?
kjett
kjett
expansion tank water pump Empty Re: expansion tank water pump
Post  Wayne Pearce October 4th 2018, 1:08 pm
Meziere makes them, pretty hefty price tag, $770.00 from Jegs.
Wayne (SAWDOFF) Pearce
Wayne Pearce
Post  kjett October 4th 2018, 1:26 pm
No kidding on that price tag! but I guess in perspective, with a $30k motor, is a $700 water pump really that bad?
kjett
kjett
Post  Wayne Pearce October 4th 2018, 5:19 pm
Agreed - but I was still a bit stunned at the price.
Wayne Pearce
Post  cool40 October 5th 2018, 12:11 am
I've used a small pump from a heat exchanger off a lightning truck. In my pulling truck I have a 8 gallon ice tank with pump inside using #12 lines. It works a little too good if I use ice so typically just run all water. This is the pump inside the ice tank https://www.ebay.com/itm/NEW-2000-GPH-Marine-Bilge-Pump-12-Volt-4-year-Warranty/311124236625?epid=1064051137&hash=item4870731951:g:Xd0AAOSwOgdYqvcj
Post  kjett October 5th 2018, 8:32 am
Cool40, your setup has me intrigued especially with the use of a bilge pump. scratch
kjett
kjett
Post  cool40 October 5th 2018, 9:17 am
kjett wrote:Cool40, your setup has me intrigued especially with the use of a bilge pump. scratch
it's worked great so far.
