598 C heads
STR-LGL-70
598 C heads
So I'm finally putting something together, parts are at Green Racing in Colorado.
C 460 heads 525/365 2.45 Ti intake valves 1.9 exh ss
WW shaft rockers 1.8 intake/1.75 exh
Scat 4.5 billet w/short snout
ATI balancer
4.6 bore
oliver billet rods
13.5.1 compression
Eliminator premier block
Double pinned roller .472 intake lobe/.451 Exh. lobe dur @.050 284 int/302 exh 114 C/L
.904 lifters Crower
C 460 ported intake w/edelbrock annular fogger titanium nozzles flowed/installed by IS.
Billet fab wet sump pan w/titan pump
Danny Bee
1450 Pro Systems gas dominator
Sheldon G.
ATI balancer
4.6 bore
oliver billet rods
13.5.1 compression
.904 lifters Crower
Danny Bee
Sheldon G.
Last edited by STR-LGL-70 on December 24th 2018, 9:02 am; edited 3 times in total (Reason for editing : compression change &cam spec)
STR-LGL-70- Posts : 223
Re: 598 C heads
The Alky dominator is going to be a bottle neck IMO
Re: 598 C heads
STR-LGL-70 wrote: most C head builds I've seen are done by 7100-7200 anyway unless I'm mistaken,
Sheldon G.
You're kidding right?
Curt- Posts : 2790
Re: 598 C heads
If you're going to run alky get a Rons systems
John Myrick- BBF CONTRIBUTOR
Re: 598 C heads
Curt wrote:STR-LGL-70 wrote: most C head builds I've seen are done by 7100-7200 anyway unless I'm mistaken,
Sheldon G.
Well I suppose it depends on the components, etc and I'm sure there are ones that peak much higher but seems like the majority I've seen posted peak around that area?
Re: 598 C heads
I think Schmitty's 632 peaked a little bit higher then that but I'm pretty sure it was done before 7800.
68formalGT- Posts : 865
Re: 598 C heads
I've done a lot of searching on here and must have overlooked it, also some of the older posts photobucket removed what pictures were posted if i'm not mistaken.
Anyway I'm going to a 1450 on gas instead of alky 1250 so that should help it breathe a little deeper.
Re: 598 C heads
Schmitty runs a little bigger carb then the 1450, Oakley supplied a 2.300" Quick Fuel for that build.
https://www.429-460.com/t20502-632-c-head-engine
Re: 598 C heads
68formalGT wrote:Schmitty runs a little bigger carb then the 1450, Oakley supplied a 2.300" Quick Fuel for that build.
Thanks for the link, badass build for sure!
Dyno Results
Ended up with 1126 hp @ 7000 and 901 tq at 6100 so i'm pretty happy with the results. Gonna be a big change from DOOE-R heads and a port-o sonic
Can only speculate with more cam and compression would it have made, definitely left some on the table. Should be a reliable bracket engine that makes good power w/o having to spin it too hard.
Also tried a BRE carb with 2.2 throttle blades and went 1151 hp.
![Laughing](https://2img.net/i/fa/i/smiles/icon_lol.gif)
hbstang likes this post
Re: 598 C heads
I think that is great results. I have more compression, more cam, and two carbs and that was 1188 at 7800 rpm.
Re: 598 C heads
1.88 horse per cube!!!!
Re: 598 C heads
I think so too, especially considering the things you mentioned. Hopefully with the smallish cam and lower compression it will reduce the maintenance somewhat. I still agree with the A heads and now the SR-71 also being the best bang for the buck.psfracer wrote:I think that is great results. Â I have more compression, more cam, and two carbs and that was 1188 at 7800 rpm.
Sheldon G.
Re: 598 C heads
68formalGT wrote:1.88 horse per cube!!!!
It's pretty good but if you check out some of the others on here they are right at 2 hp per cube. The C heads and Keith Fulps' interceptor heads are pretty serious pieces. I do believe Freelander is sandbagging a bit on his 638
![Razz](https://2img.net/i/fa/i/smiles/icon_razz.gif)
Sheldon G
Re: 598 C heads
Sheldon? was this Dyno'd at Monte shop and the numbers corrected for sea level?
powerstrokeace- Posts : 1496
Re: 598 C heads
powerstrokeace wrote:Sheldon? was this Dyno'd at Monte shop and the numbers corrected for sea level?
Haxton is 4000' above sea level.
Re: 598 C heads
Yes, it was dynoed at Monte's shop but I will have to find out about the correction factor. Monte did say that the weather wasn't the best the day they got final #'s or it may have made a little more. Also there was no spacer between carb and intake so there is probably a little there as well. I do have a dyno pull video but don't know how to post it.
Re: 598 C heads
Yes, numbers are corrected.
Re: 598 C heads
STR-LGL-70 wrote:Ended up with 1126 hp @ 7000 and 901 tq at 6100 so i'm pretty happy with the results. Gonna be a big change from DOOE-R heads and a port-o sonic![]()
That thing would love being 15.5/1.
Re: 598 C heads
When do you think you'll get a chance to put it on the track and make a pass?
Re: 598 C heads
Lem Evans wrote:STR-LGL-70 wrote:Ended up with 1126 hp @ 7000 and 901 tq at 6100 so i'm pretty happy with the results. Gonna be a big change from DOOE-R heads and a port-o sonic![]()
Yes sir it would! Decided on the lower compression so when I'm ready to start using the fogger set up I would have less chance of hurting it.
Re: 598 C heads
68formalGT wrote:When do you think you'll get a chance to put it on the track and make a pass?
I'd say best case 2 or 3 months. I need to do a rear shock up grade, new slicks, chute and I'm sure I'll run into other things. Would also like to change the input shaft on the C-6 while it's out.
Re: 598 C heads
Finally had the time to work on the car; re did the fuel system front to back, etc so I could drive it. I can tell you it's a big change in the way it feels compared to the old engine from the driver's seat! Have to tidy up some electrical and get a better driveshaft before I go to the track; hopefully next month if Orlando is not shut down with this virus going around. If I could post a video here I would but don't know how. I put one on BBF dragracing facebook page but one of the mods took it down.
Sheldon G
Sheldon G
» Wanted..... Cast iron Blue thunder Ford port heads or CJ heads
» FS: New set of Ford M-6049-SCJA aluminum cylinder heads.. HEADS SOLD, Thx
