Distributor Gear Choices
wickettoby1
I fired up the old google machine and wasn’t impressed with what I found. My question is does anyone make a composite or melonized .531” dist gear for the 385 series engines? My new build utilizes a billet roller and would prefer not to use a bronze gear.
Thanks Justin
Thanks Justin
wickettoby1- Posts : 352
Re: Distributor Gear Choices
There was some talk of this a while back, but not sure that any cam company ever stepped up to make it for the BBF.
BBFTorino- Posts : 999
I did find that Tritecmotorsports.com sells a composite gear but they provide basically no info about it on their website.
wickettoby1 wrote:I fired up the old google machine and wasn’t impressed with what I found. My question is does anyone make a composite or melonized .531” dist gear for the 385 series engines? My new build utilizes a billet roller and would prefer not to use a bronze gear.
Thanks Justin
YES, "TriTec Motorsports" in Fenton, Michigan offers a 335/385 composite distributor gear for use with Cleveland and big block Ford distributors. Whatever information you need ... just call 'em.
(810) 655-3900
Hey Randy
Have you used the composite gears in some of your builds? If yes how is the wearability compared to a bronze gear?
They have a website too. Looks interesting:
https://www.tritecmotorsports.com/products/gears
cletus66- Posts : 865
wickettoby1 wrote:Hey Randy
I have used them in several builds.
As to longevity ... I don't know; no one has ever brought one back.
Well I guess no come backs is a start. Have these builds utilized HV or HP oil pumps or tight oil clearances that would put extra strain on the drive gear?
wickettoby1 wrote:Well I guess no come backs is a start. Have these builds utilized HV or HP oil pumps or tight oil clearances that would put extra strain on the drive gear?
A lot of people would consider these as tight oil clearances; I NEVER use a high volume pump.
Okey dokey
I did find a Crane gear that they claim is compatible with a steel roller cam, I need to contact them to see what they say.
https://www.summitracing.com/parts/crn-52971-1
wickettoby1 wrote:Okey dokey
Use whatever you want to use.
I was asking because I don't/didnt know what gear to use. With a billet roller I know I can run a bronze but the lifespan isn't the best. At this point I'm leaning towards the composite from Tri Tec.
There are many bronze gear choices that aren't up to task because of the material. Bronze material grades that have nickel and aluminum are very good for this application as they are widely used for bearings. The low end ebay (nameless) gears are mostly tin/ lead/zinc alloy's. Not to long ago I bought a gear from a large ebay dealer that advertised a nickel/aluminum bronze for half the cost of and MSD replacement gear. I had it scanned at work to find it to be a low end alloy.
The MSD gears that I have used were scanned to be the correct bearing grade alloy for this use. MSD gears have performed well for my street/strip use. My concerns for using a composite material is in the strength of the material. I would need to know more information and compare it to usable bronze.
Dave De- Posts : 797
Thanks for the info Dave. I like the idea of a bronze gear made from quality materials but not a big fan of ANY sort of metal being circulated through the oil system. If I knew more about gear types and the hardness measurenents of a material id call Tri Tec and quiz them on their composite gear.
Dave De wrote:There are many bronze gear choices that aren't up to task because of the material. Bronze material grades that have nickel and aluminum are very good for this application as they are widely used for bearings. The low end ebay (nameless) gears are mostly tin/ lead/zinc alloy's. Not to long ago I bought a gear from a large ebay dealer that advertised a nickel/aluminum bronze for half the cost of and MSD replacement gear. I had it scanned at work to find it to be a low end alloy.
Interesting. what kind of scanner is capable of that? That sounds pretty cool.
stanger68- Posts : 500
The device is called an XRF (X Ray Flourescence). A hand held x ray tube that can detect most elements in metals to determine the alloys.
http://handheldxrfanalyzer.com/index.php?route=product/product&product_id=59
Only $14K, I think I'll buy two
I don't drive a bunch of miles but also have never had any problems with the MSD bronze gears!!
Mark Miller- Posts : 1954
Just my limited experience.
I had run a Crane solid roller (8620 carburized core) with the Crane steel distributor gear.
Over a few years the distributor gear showed a little wear - not much.
However when performing an inspection the gear on the camshaft had at least twice as much wear as the distributor gear.
I have since run an MSD bronze gear - changed camshaft as well.
I am nowhere near 1000 miles per year, thus the bronze gear choice.
Also one can run a non bypass type oil filter if concerned about bronze in the oil.
Cheers
Cheers
68galaxie- Posts : 351
Damn! That’s straight outta Hollywood right there!Dave De wrote:stanger68 wrote:
» Distributor Gear fit
» distributor gear pin
» distributor gear
» Which distributor gear
» eliminator block oil modifications
» distributor gear
