need some more parts !
fordman460
DanH
Fat Fender 460
need some more parts ! Empty need some more parts !
Post  Fat Fender 460 December 21st 2009, 3:14 am
wtb some stuff for a 460a
Distributer
std bearings rods and mains
std rings
oil pump and tube for rear sump
like to have a fair used carb
alt and power steering brackets.
used cam for automatic c6
c6 torque
dont need anything special just trying to get it started for now and upgrade it later this summer. Thanks
Fat Fender 460
Fat Fender 460
need some more parts ! Empty Re: need some more parts !
Post  DanH December 21st 2009, 4:02 am
Fat Fender 460 wrote:wtb some stuff for a 460a
Distributer
std rings
c6 torque
get a ring and bearing kit, comes w/gaskets- the rest can be had at a pick-n-pull place. shipping is a good percent of the cost for the parts you need
DanH
need some more parts ! Empty Carb.
Post  fordman460 December 21st 2009, 7:15 pm
What size carb do ya need? I have about 20 Holleys around here.
fordman460
fordman460
need some more parts ! Empty carb
Post  blown473 December 21st 2009, 8:46 pm
I have a 750 vac secondary holley for $100. + shipping. Thats a good size for a mild 460 . I have the same truck as you; started the same way, and old truck I paid $275. for 20 years ago and slowly built it up. Now its black and blown! You will love your truck with a 460 in it. Fits awesome and these trucks love the torque. Good luck with your truck!
blown473
blown473
Post  Fat Fender 460 December 21st 2009, 9:03 pm
i would like to have a 750 or bigger carb. If have one that needs some work that is what im after as long as its fixable. thanks. do you have any pics of your truck.
Fat Fender 460
Fat Fender 460
need some more parts ! Empty carb and pics
Post  blown473 December 21st 2009, 10:02 pm
The 750holley I have has been sitting awhile , I would put a kit in it, its cheap to do . Its a newer model with elect choke, pretty nice. I posted pics on the car buildup forum on this site and on the other site www.460ford.com Its under "myf100" blown473 lots of pics. tons of parts available for these trucks. It has been a very fun build. If I can help with yours just send a message, I have a whole group of friends who have these trucks, and I've worked on them for about 20 years. Oh almost forgot that holley comes with a chrome 14" aircleaner that says "ford performance" on it.
blown473
blown473
Post  bbf-falcon December 22nd 2009, 8:03 pm
Fat Fender 460 wrote:i would like to have a 750 or bigger carb. If have one that needs some work that is what im after as long as its fixable. thanks. do you have any pics of your truck.
John,Let Randy Spohn have that 750 and it will work like new when you get it back. I have a 2800 Stahl converter for a C6,and MIGHT have a cam/lifters.
Post  Fat Fender 460 December 22nd 2009, 10:27 pm
ok sounds good i could use both of them just give me a price when u get a chance. i have ran into a problem with the frame of the truck. I'm not sure if i should cut the straight axle out or keep it.
Fat Fender 460
Fat Fender 460
need some more parts ! Empty frame problem
Post  blown473 December 23rd 2009, 1:51 am
Whats up with your frame? Theres a ton of ways you can go on these trucks, drop axle, camero clip, volare clip, mustang 2 . I stayed with the drop axle, 2" drop with reverse leafs that made a total of 4" drop. Only thing I don't like about the drop axle suspension is on rough roads you get bump steer.
blown473
blown473
Post  Fat Fender 460 December 23rd 2009, 2:09 am
does it handle very well or is it a straight liner?
Fat Fender 460
Fat Fender 460
need some more parts ! Empty F100 handling
Post  blown473 December 24th 2009, 12:27 am
Strangely enough it goes around corners like a go kart! Heres what we did: besides the 2" drop axle and reverse eyed leafs we added 1 more leaf plate to each of the front spring packs, and put the slippery plastic in between each leaf, (you need u bolts 1" longer to do this, easily obtained at any spring shop) and we also added a big front sway bar made by No Limit engineering. We also added "pro shocks" brand shocks made for lowered trucks. We replaced every bronze bushing and steel pins in all the springs front and back. Removed 4 springs from the rear pack and used vintage fords rear lowering shackle to drop the rear a total of 4" . Lowered type shocks on rear as well, and "No Limit " engineering ladderbar set up made just for the 1953-1956 f100. The steering box was completely rebuilt along with the drag link with parts from vintage ford. I run 245-50-vr15 comp t/a tires on the front and either a 295-50-15 radial or a 10.5 slick on the rear depending on what I'm doing. With the street tires on there it goes great around the turns. My front bumper is only about 8.5 inches off the ground. There is very little lean in the turns, its pretty much flat, and thats what no limit says about their front bar, it really helps these trucks alot. Mine does ride alittle stiff, but ok, its just the really rough roads that make it want to bump steer. They tell me adding power steering to these trucks like the toyota 4x4 box conversion really smooths that out, one friend who was a line mech. at a ford dealer swears by it on his 56f100., mine is still manual but I've started gathering the parts to do the power steering.
blown473
blown473
Post  Fat Fender 460 December 31st 2009, 2:35 am
fordman460 wrote:What size carb do ya need? I have about 20 Holleys around here.
i would like to have a 750 or so maybe a little bigger have any laying around like this. just need some thing to start with or that is able to be rebuilt. thanks
Fat Fender 460
Fat Fender 460
Post  the Coug December 31st 2009, 3:11 am
personally I would put MustangII suspension on it with rack and pinion....
need some more parts ! Empty 750 Holley.
Post  fordman460 December 31st 2009, 5:59 am
I have a couple 750 vac secondary carbs. Same price as you were offered by another($100.00 and shipping). He offered an air cleaner too so his is the better deal w/electric choke. I have both, w/ford trans kick-down and without and both are manual choke. I am in Indiana 47452. Distance could be a factor when you consider shipping.
fordman460
fordman460
need some more parts ! Empty frame changes
Post  Fat Fender 460 December 31st 2009, 8:51 pm
the Coug wrote:personally I would put MustangII suspension on it with rack and pinion....
I have recently came across the complete front frame section from a 2002 ranger that has A-arms and coil suspension with a rack and pinion. I worked on it all day today and cut off the original frame and installed the new front clip, got a lot done a little welding left to do on Saturday and it will be a rolling chassis again. hoping to drive in the next month or two. Very Happy Very Happy
Fat Fender 460
Fat Fender 460
need some more parts ! Empty new front end
Post  blown473 December 31st 2009, 11:17 pm
Post some pics of that new front end when you have the time, would like to see it. You will have to let us all know how it drives when you get done. Very Happy
blown473
blown473
Post  Nevs December 31st 2009, 11:23 pm
I think you will be a lot happier with this front suspension over the straight axle! Pictures please.
need some more parts ! Empty front suspension changes
Post  Fat Fender 460 December 31st 2009, 11:31 pm
i will start a new post in the chassis section. so far so good on the swap it has only took 6 hours so far.
Fat Fender 460
Fat Fender 460
