Total timing on A460 head 538
Can anyone give a good starting point on total timing for a A460 head 538 ci 13.8 compression on alcohol I’m running this in a rear engine dragster elevation at 5400 ft I’ve been running 34 -36 degrees. Just wondering if i’m any where close Thank you
red6157- Posts : 10
Re: Total timing on A460 head 538
28/30 is about right on gasoline with those heads so, a little less with methanol would be near what it should be at near sea level. Maybe a bit more at a high altitude.
Last edited by rmcomprandy on December 21st 2018, 10:52 pm; edited 1 time in total
thanks I’ll give it try
red6157- Posts : 10
I've had better results with less on my 526 A-head deal. It was happy with 26* on alky but your results may vary in that higher altitude.
26 interesting. are you running a locked out distributor or crank trigger? What is your elevation. I’m in Montana so I have to wait until the snow goes away but anxious to try that. thank you
red6157- Posts : 10
I was running a locked distributor on it. We're around 1000' or so I think.red6157 wrote:26 interesting. are you running a locked out distributor or crank trigger? What is your elevation. I’m in Montana so I have to wait until the snow goes away but anxious to try that. thank you
» C8 head and total timing
» Total timing with 10.5:1 Compression
» A460 head
» any first hand exp on total car weight foxbody with iron head bbf ?
» How do I stop the detonation
» A460 head
