Builder near Daytona Beach
Any suggestions on a machine shop relatively close who knows how to get the most out of a 429/460 on a working guy's budget?
I have a standard bore 429/460 block, a set of D3 heads that have been ported w/ stainless steel cj valves and roller rockers, a stock 429 crank and an unknown brand stroker crank, a weiand high rise intake and dreams. Open to suggestions. Thanks!
RDZE57- Posts : 2
Re: Builder near Daytona Beach
RDZE57 wrote:Any suggestions on a machine shop relatively close who knows how to get the most out of a 429/460 on a working guy's budget?
Read through the "Proven Builds" section and it should give you some ideas.
Is your stroker crank 4.14/4.15 ?
STR-LGL-70- Posts : 223
For general machining I would use the shop @ Charles st. & George Ingram; I believe it's Daytona Auto Machine. If you need something more race oriented try Express in Deland or Powered by Ford in Orlando.
If you don't mind a bit of a drive, Powerhouse Machine in Ocala, Fl will do you right. Dave the owner is a straight shooter and excellent machinist.
He has done three blocks for me and balancing on 2 rotating assemblies and they were done right. He does a lot of BBF stuff for the truck and airboat guys around central florida, so he knows the 460.
fordguy69- Posts : 98
Thanks! Exactly what I was looking for.
RDZE57- Posts : 2
