C4 Transbrake transmission & Art Carr 9" Torque converter
 C4  Transbrake transmission & Art Carr 9" Torque converter Empty C4 Transbrake transmission & Art Carr 9" Torque converter
Post  harry k February 14th 2019, 2:37 pm
Ford C4 Drag Racing Transmission & Art Carr 9" 5500 + RPM stall anti ballooning plate torque converter
(stall depending the torque output of your engine will vary)
Transmission has PA Performance transbrake, Alto racing rigid band with red eagle clutches and Kolene nitrided steel plates. PTFE teflon rings, Sonnax C ratio purple billet servo, Billet input shaft,6 pinion front planetary, the case has been tapped for overflow (NHRA rules)
cast aluminum deep pan (magnet attached to it at the bttm of pan) & JW Ultrabell sfi bellhousing for BBF, -6 cooler line fittings
This build will be good for 800HP !!!
trans and torque converter freshened up and have not been used,ready for the new year race season for you.
asking $3450 or best offer!!
 C4  Transbrake transmission & Art Carr 9" Torque converter 00g0g_ld1JOmocqy7_1200x900
harry k
 C4  Transbrake transmission & Art Carr 9" Torque converter Empty Re: C4 Transbrake transmission & Art Carr 9" Torque converter
Post  harry k September 18th 2019, 11:10 am
MAKE AN OFFER !!!
 C4  Transbrake transmission & Art Carr 9" Torque converter 410
harry k
