572 TFS AHead timing question
572 TFS AHead timing question Empty 572 TFS AHead timing question
Post  away April 2nd 2019, 9:26 am
How much timing are you guys running with methanol (Ron's terminator) with an engine combo like this? Particularly interested in the quys that have dyno'ed or track tested with this set-up. Obviously track only solid roller deal 15.5:1 compression
Also what would be your Alky tune-up? Jet and pill size with 0 1/2 pump
away
away
572 TFS AHead timing question Empty Re: 572 TFS AHead timing question
Post  rmcomprandy April 2nd 2019, 9:35 am
away wrote:How much timing are you guys running with methanol (Ron's terminator) with an engine combo like this?  Particularly interested in the quys that have dyno'ed or track tested with this set-up.  Obviously track only solid roller deal 15.5:1 compression
About 26 degrees total is near normal with alcohol.
Post  away April 2nd 2019, 4:56 pm
https://www.enginebuildermag.com/2017/09/understanding-ignition-timing-making-maximum-power-means-knowing-science/
After that comment of only 26 degrees! I had to do a little studying. This is a good read that may explain things.
away
away
Post  Lem Evans April 2nd 2019, 11:50 pm
32* - 34* with gas. Seems strange to have 6* - 8* less for alky.
Post  StephenW April 3rd 2019, 1:58 am
My 632 likes 32* with a Bird Catcher.
StephenW
StephenW
Post  cool40 April 4th 2019, 12:00 am
I’ve ran low as 26* with my Motorsport headed 526”. I think my 605” is on 32* but really can’t recall.
Post  away April 4th 2019, 2:08 pm
cool40 wrote:I’ve ran low as 26* with my Motorsport headed 526”. I think my 605” is on 32* but really can’t recall.
On the 526 you must have had a very strong ignition system or running lean. What ignition system are you running?
away
away
Post  rmcomprandy April 4th 2019, 2:29 pm
Lee ... is your car going to be at the June memorial event this year ...?
Post  cool40 April 7th 2019, 1:04 am
I track tested it very thoroughly and it ran best @26*. I was told by others it must need fuel but it slowed down with more fuel every time. Ignition is a 7al2 with pro power coil. It ran 5.40 in 100* weather.
Post  cool40 April 7th 2019, 1:07 am
probably not. I haven’t ran it since the last time you saw it at us60. I’ve gotten into the truck pulling sickness but still haven’t give up on racing yet.
