rev kit for a 460
AZFairlane
Kobelco
rev kit for a 460 Empty rev kit for a 460
Post  Kobelco April 30th 2019, 9:39 pm
Is there one avail?
Kobelco
rev kit for a 460 Empty Re: rev kit for a 460
Post  AZFairlane May 2nd 2019, 12:28 am
I don't know of any for splayed valve engines, e.g. Clevelands, or BBF. There is one for a BBC, I just don't know how much modification it would need to run on a BBF. Has anyone used a BBC rev kit on a BBF?
Last edited by AZFairlane on May 2nd 2019, 12:33 am; edited 1 time in total (Reason for editing : New information.)
AZFairlane
AZFairlane
Post  Paul Kane May 2nd 2019, 12:18 pm
Kobelco wrote:rev kit for a 460...Is there one avail?
The best rev kit for a 460 engine that I have ever seen is awesome, highly effective, and has been repeatedly proven to 10,000 rpm. It's made up as follows:
  • a 385 Series valve train that is made up of quality components and optimally set up for the intended application
Post  IDT-572 May 2nd 2019, 12:32 pm
Razz Razz Cool Cool
Post  Kobelco May 2nd 2019, 8:45 pm
bend a push rod and keep going the lifters will do what to a cam?? and oil pressure may go south also depends on if lifter pops out.
Kobelco
Post  rmcomprandy May 3rd 2019, 9:50 am
Kobelco wrote:bend a push rod and  keep going the lifters will do what to a cam??  and oil pressure may go south also depends on if lifter pops out.
Just why are you not stopping and going on...? Do you not recognize that something is wrong...?
Roller lifters have a tie bar and will not just pop out.
A sheet metal baffle will prevent flat tappets from exiting their bores.
Post  wayney May 3rd 2019, 9:30 pm
A sheet metal baffle will prevent flat tappets from exiting their bores. Now that's a good idea randy .. I like!!!
wayne
wayney
Post  dfree383 May 4th 2019, 9:00 am
Build it right and maintain it you won't have issues
Post  rmcomprandy May 4th 2019, 11:07 am
wayne
I had them pre-made some 30 years ago. Have about 10 remaining.
Also helps with preventing hot oil splash on the bottom of a non-air-gap type intake manifold.
Post  Curt May 7th 2019, 9:50 am
I think you'll find that most of us will kill the power after dropping a cylinder. Your results may vary. Suspect
Post  jasonf May 7th 2019, 10:48 am
With one lifter out you will still have 15 psi oil pressure at 3500. Years ago I had one pop out when I was driving in the Rocky Mountains at 2 am. I thought it was something more catastrophic so I figured "F it" and kept driving to the next town. I didn't feel like be stranded in the pitch black on the side of a 2 lane road in the mountains. Once I pulled the valve covers off and found a bent pushrod I put the lifter back in. Ordered slightly different pushrods after checking the contact pattern on the valve and that engine ran for plenty more years.
