BBF 64 Galaxie
+6
68galaxie
427John
away
nedceifus
10 posters
BBF 64 Galaxie Empty BBF 64 Galaxie
Post  nedceifus July 31st 2019, 10:00 am
Howdy, a member from the 460.com site steered me over here. I have a 64 Ford with a 460 I built 20 years ago. The project has sat idle for a few years but Is back on the front burner. I will start a build thread before long. Just want to soak up knowledge from this site. BBF 64 Galaxie 9bf0da10
BBF 64 Galaxie 997cc710
BBF 64 Galaxie 0216bc10BBF 64 Galaxie 9bf0da10
nedceifus
nedceifus
BBF 64 Galaxie Empty Re: BBF 64 Galaxie
Post  away July 31st 2019, 4:34 pm
That will be a nice ride! cheers
away
away
Post  Mike R July 31st 2019, 6:23 pm
Good to see ya Very Happy
BBF 64 Galaxie Empty Race help
Post  nedceifus August 1st 2019, 3:23 pm
This Galaxie of mine is a street car. But I want to race too! Can you recommend a build thread with a similar heavy street/strip car? I’m thinking about 10 second 1/4 mile times, 650 pump gas horse. Just want to see what other people have built. My old 460 is going to do its thing for now but I want to set myself up for a built to the hilt street stroker here before too long. When I get to the point that I can afford a stroker motor, I want everything else on the car prepped to handle & plant the power. BBF 64 Galaxie 8bd2c910
nedceifus
nedceifus
Post  427John August 4th 2019, 1:39 pm
If your plans don't include a narrowed rear you may want to upgrade your rear to a big bearing housing and 31 spline axles.A housing from a 60-64 ford or 61-64 merc wagon will bolt right in and have the big bearings.A quick and easy way to tell the big bearing is the bearing retainer nuts,9/16 socket =small bearing 3/4 socket = big bearing for these housings.These will still have 28 spline axles,but they will accept 31 spline.
427John
nedceifus likes this post
Post  68galaxie January 2nd 2020, 1:36 pm
Awesome ride!!
68galaxie
68galaxie
Post  nedceifus May 12th 2022, 8:16 am
427John wrote:If your plans don't include a narrowed rear you may want to upgrade your rear to a big bearing housing and 31 spline axles.A housing from a 60-64 ford or 61-64 merc wagon will bolt right in and have the big bearings.A quick and easy way to tell the big bearing is the bearing retainer nuts,9/16 socket =small bearing 3/4 socket = big bearing for these housings.These will still have 28 spline axles,but they will accept 31 spline.
Word. I narrowed the rearend 1/4” on each side a while back. Re used my small bearing ends. I agree, I need big bearing ends & will be cutting the rearend apart again soon.
nedceifus
nedceifus
Post  nedceifus May 12th 2022, 8:26 am
Reviving this thread out of boredom. Some of you regulars, all 3 of you,🤣, may have noticed my plethora of questions on the site the last few months. I’ll try to keep the description of the gap in this thread short, but here is where we have been & where we are. I was not happy with the way the big block was fitting in the engine bay with the Mustang II. It was either to tall or too far forward or I was going to have to completely rebuild my firewall. Basically I got pissed off, sold my big block & bought a 5.3 LS & a turbo. The LS fit nice, I’m sure it would have ran hard, but the sac relig of putting that thing in my Ford got to me. So here I am a couple years & a divorce later & I want to get this thing going again. Traded my LS for a 460 & have been working on getting it together for a couple of months. Trying to support site vendors where I can. Had Lem grind my cam & bought a pair of SCJ heads from him. Rocker girdle & carb spacer from Jomar.
nedceifus
nedceifus
Post  nedceifus May 12th 2022, 12:39 pm
This is what I have going. Trying to keep this kinda traditional. Like a 90’s street race car: Bad to the bone but street. Used parts where I can find them. Nothing to fancy or modern.
460 bored .30 DIVE block
Stock crank
Eagle I beam rods
Waiting on RaceTech pistons, 10.1 for SCJ
SCJ heads, stock ports with a backcut on the intake valves
Waiting on Comp Ultra Magnum rockers
Lem Evans solid roller cam
Jomar rocker girdle
Victor 460 for a 4150 (I may or may not port match to SCJ, probably not)
1000cfm 4150 from AED
1” Jomar power cone
Old Moroso valve covers & air cleaner
MSD 6AL
MSD pro billet
10” PTC converter
nedceifus
nedceifus
Post  nedceifus May 12th 2022, 12:44 pm
Yesterday I tried on a 295/55/15 Mickey Thompson ET Street SS. It’s perfect. BBF 64 Galaxie F7122910BBF 64 Galaxie F7122910
BBF 64 Galaxie 86f2b810BBF 64 Galaxie F7122910
nedceifus
nedceifus
Post  BBFTorino May 13th 2022, 9:41 pm
Even though it's not my car, thank you for keeping your classic Ford, all Ford!
So you will have 466 cubic inches with nice flowing heads and intake. I'm betting that it would make more power than a tiny 5.3 LS.
Post  rmk57 May 16th 2022, 11:36 am
If it were me and also if your starting from scratch I'd look into a stroker kit. A 521-545 Scat or Eagle kits are reasonable, not sure about availability though.
I really like the 64 Galaxie body. They look great with the teardrop hood treatment.
rmk57
Mark Miller and nedceifus like this post
Post  wickettoby1 May 16th 2022, 9:11 pm
nedceifus wrote:This is what I have going. Trying to keep this kinda traditional. Like a 90’s street race car: Bad to the bone but street. Used parts where I can find them. Nothing to fancy or modern.
Stock crank
Eagle I beam rods
Jomar rocker girdle
1” Jomar power cone
MSD 6AL
MSD pro billet
10” PTC converter
What headers do you plan on using?
What is the width and backspacing on the rear wheels?
wickettoby1
Post  nedceifus June 16th 2022, 9:49 am
Stock crank
Eagle I beam rods
Jomar rocker girdle
1” Jomar power cone
MSD 6AL
MSD pro billet
10” PTC converter
4.5” backspacing on the rear wheels. I’ve got a set of Hooker Super Comps off the fox body Mustang I pulled the motor from.
nedceifus
nedceifus
Post  nedceifus June 16th 2022, 9:51 am
All short block parts are at the machine shop. Finally got my pistons & rockers. Still waiting on head studs, but I have a set of SpeedMasters I can use till the ARP’s show up.
nedceifus
nedceifus
Post  nedceifus August 28th 2022, 10:53 pm
BBF 64 Galaxie 5d147b10
Intake
nedceifus
nedceifus
Post  nedceifus September 2nd 2022, 10:19 am
Going to glue the tin valve covers to the aluminum spacers so they don’t leak anymore…BBF 64 Galaxie 76f60910
BBF 64 Galaxie F7705910BBF 64 Galaxie 76f60910
nedceifus
nedceifus
jasonf likes this post
Post  nedceifus September 2nd 2022, 10:20 am
Christ, I hope I can build cars better than I can run this hand held computer thingy…
nedceifus
nedceifus
Post  supervel45 September 2nd 2022, 3:16 pm
Should have kept the M/T valve covers, they are worth about as much as a JY LS. Like the car and second the Tear Drop hood scoop.
Hey now, I think we have at least 7 regular members left here. Sleep
Post  nedceifus September 27th 2022, 10:10 am
BBF 64 Galaxie D9d7a010
BBF 64 Galaxie E195a710
BBF 64 Galaxie 24389c10
Back from the machine shop!
nedceifus
nedceifus
Post  Mark Miller September 27th 2022, 10:45 pm
Looks almost ready to run is that a Fox Body Canton Oil Pan?
Post  nedceifus September 28th 2022, 11:41 am
It is. Mustang II suspension in the car. No oil pan plays nice with the Mustang II but this is as good as it gets.
nedceifus
nedceifus
Post  nedceifus October 10th 2022, 10:22 am
OK, sat the motor down in the engine bay. Thought I may have been over thinking or being dramatic back in 2019 when I sold my big block & bought an LS for this thing. But, this 460 hates the mustang2 front suspension. So, lastnight I cut out the majority of the firewall. Moving the motor back 8” in relation to where it startles the firewall. Going to modify the mustang2 crossmember so that the balancer sits right above the rack. Any other option would be 1/2 assing it. I did not want this much work, or to cut my car up like this. But it had to happen. I realize I could have changed my suspension again, or found another original frame. But this is what I am doing. This car is going to live on the street. I figure the weight bias may help me hook on shitty surfaces.BBF 64 Galaxie 66eb6710BBF 64 Galaxie 66eb6710
nedceifus
nedceifus
Post  supervel45 October 10th 2022, 9:38 pm
You might as well go for a Tilt at this point. Question
https://www.dreamstime.com/royalty-free-stock-image-ford-drag-racer-late-s-sedan-has-been-converted-dragster-addition-high-performance-v-engine-tilt-front-image40473386
Post  nedceifus October 11th 2022, 8:18 am
Ha! Yea. 500hp “drag car”
nedceifus
nedceifus
