Enderle injection setup
Enderle injection setup Empty Enderle injection setup
Post  johndickjr August 24th 2019, 11:11 pm
Looking for little info on a Enderle alcohol injection, im new to tuning on this and I feel i am going in the right direction, but always willing to learn.So I started driving my granddads ford fairmont, he passed away in 2011 , car is a full tube chassis car, fiberglass frontend, hood, doors.. has a power glide with 5500 converter and 4.56 gears with 32x14 slicks 4 link ..motor is a 514 ci BBF..ported dove heads, roller cam 730/745 lift 286/290 @.050...i need a idea about what size nozzle should be in it and return pill, i do not know what pump we have other then it’s mounted to the cam
johndickjr
Enderle injection setup Empty Re: Enderle injection setup
Post  69F100 August 25th 2019, 5:58 am
I run a Ron's tolit on my 552 with 39 nozzle I forget what size the return pill is I have different sizes . I was running 37 on the nozzles but my water temp was climbing on the top end so I went back to the 39 nozzles. Call Ron he can tell you what size to run and have you real close
Post  litshoot August 25th 2019, 10:01 am
Without knowing pump size its going to be a lot of guessing on what to run. Its possible to send it out, or if someone local can flow the system check the pump and so on
litshoot
Post  Paul Kane August 25th 2019, 3:15 pm
johndickjr wrote:Looking for little info on a Enderle alcohol injection, im new to tuning on this...motor is a 514 ci BBF..ported dove heads, roller cam 730/745 lift 286/290 @.050...i need a idea about what size nozzle should be in it and return pill, i do not know what pump we have other then it’s mounted to the cam
Buy this book, it used to cost $100 retail and is worth every penny and more:
Enderle injection setup Firs
Available by clicking here:
https://racecarbook.com/shop/fuel-injection-racing-secrets-2nd-edition/
Post  cool40 August 26th 2019, 12:52 am
It should say what the pump is right on it. 80-A-1/2 probably. I run a 36 and tried 38. Basically just made for a different main pill to run pretty much the same numbers. Look on spud millers site fuel injection enterprises and use the tune up calculators.
