Cj 4 bolt caps
Cj 4 bolt caps
Does anybody have any caps from a from a factory 4 bolt block laying around they would part with? I have a std bore block missing one. Thanks
Last edited by lance flake on November 11th 2019, 11:06 pm; edited 1 time in total (Reason for editing : Sp)
lance flake- Posts : 142
Re: Cj 4 bolt caps
There can be quite big mismatches in cap main bore from block to block. Least you can expect is to machine the cap down quite a bit and align bore unless you get very lucky.
I have some of them and this is what I found.
Calypso- Posts : 71
Re: Cj 4 bolt caps
Calypso wrote:There can be quite big mismatches in cap main bore from block to block. Least you can expect is to machine the cap down quite a bit and align bore unless you get very lucky.
Yes sir I am aware of the fit issue. I looked on pro-gram's web site didn't see any cj replacements. I would buy some aftermarket steel caps to put on this block if anybody knows were I can get some. I can handle everything but the aline bore/hone in house.
Re: Cj 4 bolt caps
I sent billet speed works an e-mail. They do still make the replacement caps per special order. I may go this route if I can not find and original.
Re: Cj 4 bolt caps
does Milodon make them for the CJ? They used to offer them in a couple configurations, if I remember correctly.
pmrphil- Posts : 170
Re: Cj 4 bolt caps
Pro-Gram Engineering made all the caps in their various configurations including the parallel bolt CJ caps for 2, 3, & 4. They have since been acquired by another company, Billet Speedworks, and it might be best to call directly and ask whether they will make that particular version. Billet SpeedWorks simply might not have updated their website yet with that version main cap.
I've known Milodon to make only the played version main caps for the 385 Series.
Re: Cj 4 bolt caps
Paul Kane wrote:Pro-Gram Engineering made all the caps in their various configurations including the parallel bolt CJ caps for 2, 3, & 4. They have since been acquired by another company, Billet Speedworks, and it might be best to call directly and ask whether they will make that particular version. Billet SpeedWorks simply might not have updated their website yet with that version main cap.
Pro-gram engineering has changed hands. The new name of the company is Billet Speed Works. Yes Paul they do still build these caps per request. I am like you the splayed cap is all I have seen the milodon's in. Thanks guys
Re: Cj 4 bolt caps
I have a set of 5 caps if you are still interested.
Staci
Staci
69BOSS- Posts : 75
