C9ve block safe to bore .080?
C9ve block safe to bore .080? Empty C9ve block safe to bore .080?
Post  racinghabbit November 18th 2019, 2:18 pm
racinghabbit
racinghabbit
C9ve block safe to bore .080? Empty Re: C9ve block safe to bore .080?
Post  rmcomprandy November 18th 2019, 3:23 pm
racinghabbit wrote:C9ve block safe to bore .080?
Depending upon the power level intended, some are and some aren't.
A sonic check will tell the story.
Post  racinghabbit November 18th 2019, 5:05 pm
700hp is the goal...
racinghabbit
racinghabbit
Post  rmcomprandy November 18th 2019, 6:37 pm
racinghabbit wrote:700hp is the goal...
Minimum .120" cylinder wall thickness unless you fill the water jacket to just below the water pump holes.
I am sure someone has taken the chance with less but, I would not recommend it.
Post  racinghabbit November 18th 2019, 6:42 pm
sounds good.. thanks.
racinghabbit
racinghabbit
Post  Lem Evans November 18th 2019, 8:37 pm
If the block will clean up at + .030 .040 or .060" go that way and save yourself the time and money of a sonic check. No magic in a .080" over bore at that power level.
