How Much Lifter Preload--Pedestal Mount Rockers
How Much Lifter Preload--Pedestal Mount Rockers Empty How Much Lifter Preload--Pedestal Mount Rockers
Post  1EFF100 December 12th 2019, 10:23 am
Hydraulic flat tappet, stock style rockers, pedestal mount.
Thanks.
1EFF100
1EFF100
How Much Lifter Preload--Pedestal Mount Rockers Empty Re: How Much Lifter Preload--Pedestal Mount Rockers
Post  BBFTorino December 12th 2019, 5:48 pm
You simply tighten them all the way down. There is no adjustment.
Post  Paul Kane December 12th 2019, 6:31 pm
1EFF100 wrote:Hydraulic flat tappet, stock style rockers, pedestal mount.
Thanks.
By working with both pedestal shims and pushrod length, I like to optimize the rocker arm geometry while netting 0.020"-0.030" plunger depression once the rocker bolt is tightened.
The last engine I built that used those 370 heads resulted in 8.55" intake pushrods and 8.60" exhaust pushrods, then whatever amount of pedestal shim resulted in 0.020" plunger depression.  I do still have those exact 3/8" diameter hardened pushrods from that engine and plenty of pedestal shims--call if you're interested.
Post  1EFF100 December 13th 2019, 11:29 am
Thanks.
Thanks Paul, I appreciate that.
I ordered a large selection of shims from Summit a couple days ago--supposed to be here today.
If I run into problems, I'll give you a call.
Thanks again.
Bruce
1EFF100
1EFF100
