521 or 545 and why?
+7
Colt Macara
Mark O'Neal
rmk57
wickettoby1
the tree man
11 posters
Page 2 of 2 Previous  1, 2
521 or 545 and why? - Page 2 Empty Re: 521 or 545 and why?
Post  the tree man May 3rd 2020, 9:47 am
Good to hear it might outlast me! I have a 6200 chip in the MSD and I finally got the hang of short shifting because initially I was bouncing off the limiter regularly in first and second. I actually thought I had a high rpm misfire. It winds out so quick and is pulling so strong that by the time I'd glance at the tach the limiter was kicking in. I may work my way up the chip ladder a bit. Again,it's a street hot rod and I don't have plans to track it so I don't really mind the bit of cushion. Protect me from myself. I was concerned this engine might turn the car into a tire fryer. Skating all over the road going up in smoke but considering it's only old school track bars (I did lengthen them 4" to get the snubbers under the spring eye and set them to touch at rest) it hooks absolutely excellent and goes straight with zero drama. Lifts the whole car and pulls the nose way up. Weight transfers great. I think a big part is tires and I'm a fan of the M&H drag radials. Having a blast with this thing while gas is cheap! Thanks again for the help.
the tree man
the tree man
Post  521Notch February 15th 2021, 1:19 pm
Long time lurker, first time poster! Seems to be lots of knowledge on here and I'm excited to have joined the BBF family finally. I'm currently in the same 521 or 545 quandry. I currently have a 521 in my fox body that I'm super happy with how it runs. Starting on a backup build and 521 or 545 seems to be the question of the day. Which way did you decide to go?
521Notch
521Notch
Post  the tree man February 15th 2021, 5:05 pm
the tree man wrote:Finally got the engine back in the car. Did a bit of carb tuning to help idle,light cruise and tip in but was very close. The cam liked 30 degrees initial and I locked it out there. Runs fargin' awesome! From 1500 RPM up the grunt is amazing. Not sure what kind of shift point I should be looking for. 6000?
Ordered my kit from Mark at Probe and I'm very pleased. We had a couple little hiccups along the way but his communication (phone calls to Canada no less) was excellent keeping me in the loop and he stepped right up. Nice. The product is great and speced out bang on. Thanks,Mark.
Shift point/redline? Any thoughts?
545
10:1
Ported SCJ's
SFT,6.55/6.55 258/262@.050 (lost a bit of lift with a full spring compared to the checker springs in my other post.)
Home ported Blue Thunder 2X4 w/2X600 Holleys
Thanks again for all the help.
the tree man
the tree man
Post  521Notch February 15th 2021, 6:05 pm
545
10:1
Ported SCJ's
Good Lord, How'd I miss that? Thanks
521Notch
521Notch
Post  the tree man February 15th 2021, 6:47 pm
You're just all fired up about your new build,and rightly so! Good luck.
the tree man
the tree man
Post  521Notch February 15th 2021, 6:52 pm
the tree man wrote:You're just all fired up about your new build,and rightly so! Good luck.
Amen Brother, Thanks for taking it easy on me! Gonna start a new thread on that now so I don't hijack this one!
521Notch
521Notch
