Need cam recomondation/opinions
Need cam recomondation/opinions Empty Need cam recomondation/opinions
Post  chris532 February 5th 2020, 6:04 pm
Need to see if this is the right camshaft for my application. I have a 1979 f150 that I do 300 ft sand drags.
Truck specs:
weight 5000lbs with driver
3.55 gear, but run in 4 low so 6.96 final drive
C6 built to Frank M sticky
34 inch tall tires
Cam specs:
Duration at .050 280in 288ex, gross lift .740 in .726 ex, lobe separation 112
Engine Specs:
572 cubic inches
SR71 heads
Mafia intake
10.5 to 1 compression, 93 octane fuel
1050 dominator
Was talking to a local engine builder, who does engines for some other sand drag guys and he thinks I need a cam with a lower separation angle to help get a heavy truck moving. He's mostly a Chevy guy, so would like the opinion of the Ford guru's.
chris532
Need cam recomondation/opinions Empty Re: Need cam recomondation/opinions
Post  Lem Evans February 5th 2020, 8:42 pm
chris532 wrote:Need to see if this is the right camshaft for my application. I have a 1979 f150 that I do 300 ft sand drags.
Truck specs:
34 inch tall tires
Cam specs:
Engine Specs:
572 cubic inches
SR71 heads
Mafia intake
1050 dominator
Cam specs are from your engine guy?
Stall speed?
Post  norm February 5th 2020, 8:57 pm
I believe that is the current cam in the engine.
norm
norm
Post  chris532 February 5th 2020, 10:45 pm
Lem,
Those are the specs from a cam Roger at Kasse sold me. Converter stall will be changed to match what engine needs.
Norm,
This is a new cam, old one had lifter rollers wear a grove in a couple of lobes
chris532
Post  Lem Evans February 6th 2020, 1:55 am
chris532 wrote:Lem,
Norm,
Lifter type?
Post  chris532 February 6th 2020, 2:21 am
Old ones were crower bushed lifters. Have read some have had that problem with them, but I believe it was my fault and not the lifters. Followed some advice I learned I should not have. Was told by dyno operator that they leave the set screw out of the polyloks for the rockers, when using a stud girdle. Ran it that way 2 seasons before saw what was happening without them in. Screwed the set screws in and lashed opened up .008 from were I had set. Live and learn
chris532
Post  Lem Evans February 6th 2020, 11:25 am
If you are looking for more low and mid range power? If so, using same or similar lobe, a narrower lsa would achieve that.
I.M.O. I'd think the SR71 heads would like more lift than your cam has.
Post  chris532 February 7th 2020, 1:48 pm
Lem Evans wrote:If you are looking for more low and mid range power? If so, using same or similar lobe,  a narrower lsa would achieve that.
Left message with one of your guys for you to call me.
chris532
Post  Lem Evans February 7th 2020, 5:43 pm
I didn't get it. Call me two seven zero - 929/5295
