97 explorer
97 explorer
any body know what rear end the explorer`s have? 8.8? how strong are they? any imput would be a help. thanks Erv.
hillbillyerv- BBF CONTRIBUTOR
Re: 97 explorer
It should be an 8.8. They are a very popular swap for jeep owners because they are the right size and fairly cheap, not to mention disc brakes.
Here is some info I found here
The Ford Explorer 8.8-Inch rear axle has found homes in numerous vehicles besides the Explorer. It has been swapped in to Ford Rangers, Bronco II's, Jeeps, Chevy S-10's and even some cars.
The 8.8-Inch axle used in the Explorer is highly desirable because it came with 31-spline axles over the typical 28-spline found in the Ranger version. There’s a 20-25 percent difference in strength between this Explorer 8.8 and the Ranger 8.8. The bigger 31-spline axle accounts for most of that, but the 3.25-inch tubes also help. The 1991-1994 versions had 10-Inch drum brakes and the 1995 and newer models come with disc brakes.
Not all Ford Rangers came with 8.8-Inch rears. The base rear end in the Ranger has been the Ford 7.5-Inch. When Ford introduced the 4.0 V-6 into the Ranger in 1990, it came with a 8.8-Inch, 28-spline rear axle. The Ford 7.5-Inch axle was standard on the non 4.0 V-6 models.
To this day, the Ranger can still be found with either the Ford 7.5 or 8.8 inch axles. The base model 8.8-inch axle is still a 28-spline, but the FX4's come with a 31-spline 8.8-Inch rear axle.
The majority of these axles came with 3.73 gears and a Traction-Lok differential. The Traction-Lok can work very well and almost like a full locker if you apply a little brake pressure with your left foot while accelerating with the right.
jasonf- BBF CONTRIBUTOR
Re: 97 explorer
thanks for the reply, i was thinking i might use it in my 63 if i can make it fit? looks real close but have not measured it yet, i wonder how it compares in strength to my round back 9 inch? ill do some searchin i guess, thanks Erv.
Re: 97 explorer
The biggest issue I have ever read about is the centered pinion. IIRC it is not offset like most 8/9"'s. As far as tough the 5.0l guys have been beating the crap out of them for years. They are quite tough and can be made tougher in need be. Or course if you already have a 9" the right size I am not sure why you would go through all the trouble.
Re: 97 explorer
i could get it for free and its allready posi, did not know bout the offset being wrong, but makes sense though,thats why i asked,sounds like 2 much work , just tryin to save some bucks, ill just buy a locker and truss for the round back,thanks for the imput. Erv.
Explorer 8.8-Inch rear axle.
They are 59 3/4" wheel flange to flange. Same or close to your '69s rear. In the future ,I will shorten one by using the short side of another unit to replace the long side. Will be for my '66 Comet with a AOD/351w.
fordman460- Posts : 100
Re: 97 explorer
sounds like a cool Comet keep us posted im thinkin bout a injected 302 n AOD for my 63 lane
8.8
i put a 8.8 in my wrangler along with a 8v and it has held up very well to the v8 and 35's. so good luck with yours.
Fat Fender 460- Posts : 45
» 98 explorer rear end (8.8)
» 1996 explorer xlt 4.0 4 door
» 2011 FORD EXPLORER .......
» 2004 Explorer ESM testing
» Fords 1973 explorer 429ci.
