Low oil pressure after warm up
airford1
Low oil pressure after warm up Empty Low oil pressure after warm up
Post  airford1 March 21st 2020, 2:06 pm
I just had my 460 freshened up. New rings and bearing micro polish the crank. Well its 65 psi at cold start and stays that high till after I make a pass then at idle the pressure drops to 25psi. Using 20/50 Valvoline zr1. Before the freshening it wouldn't drop below 40 psi. Should I be concerned? It goes back up to 60psi as soon as I bring the rpm up above 900
airford1
airford1
Low oil pressure after warm up Empty Re: Low oil pressure after warm up
Post  rmcomprandy March 21st 2020, 3:17 pm
airford1 wrote:I just had my 460 freshened up. New rings and bearing micro polish the crank. Well its 65 psi at cold start and stays that high till after I make a pass then at idle the pressure drops to 25psi. Using 20/50 Valvoline zr1. Before the freshening it wouldn't drop below 40 psi. Should I be concerned? It goes back up to 60psi as soon as I bring the rpm up above 900
The engine clearances or oil pump probably have something different than before the "freshen-up".
I don't see any problem with 25 pounds oil pressure at idle.
Post  airford1 March 21st 2020, 8:15 pm
Kind of my thought Thanks randy.
airford1
airford1
Post  Frank Merkl March 21st 2020, 11:25 pm
pressures sound good to me ! send it!
Post  Mark O'Neal March 22nd 2020, 3:13 pm
Might be cam bearing clearance, but certainly not something to worry about.
Mark O'Neal
Post  gt350hr March 23rd 2020, 2:04 pm
As long as the pressure goes up at RPM you are good . No "reason" to have 40 or more at idle. 25 is fine as others have already said.
gt350hr
Post  airford1 March 23rd 2020, 3:44 pm
thanks guys
airford1
airford1
Post  away April 10th 2020, 10:02 pm
Lifters in backwards. Tie bars to the inside!
away
away
Post  airford1 April 13th 2020, 10:10 am
away wrote:Lifters in backwards.  Tie bars to the inside!
Funny guy, that has to be it.
airford1
airford1
