push rod length
push rod length Empty push rod length
Post  64GASSER August 25th 2020, 5:44 am
I'm building a 1973 460 with 1969 heads with cj valves .530 lift cam. can i use the stock push rods from the 73 engine ? thanks
64GASSER
push rod length Empty Re: push rod length
Post  Mark Miller August 25th 2020, 11:03 pm
If the 69 Heads have guide plates the 73 pushrods won't work because they're not hardened and you should probably check to see how long of a pushrod you need!!
64GASSER likes this post
Post  64GASSER August 26th 2020, 6:09 am
thank you
64GASSER
