Broken parts in core C6 trans
Re: Broken parts in core C6 trans
In the first picture you can see the groove that was ground into the side by some previous rebuilder.
Also found out the case had been grappled on both sides, probably from a junkyard, and I'm considering the case is now junk too.
XEngr- Posts : 71
Better take a good look at the lube return . Not common for a failure like that ,
Also what you refer to as grooves ground by a previous builder are factory
What does the rest look like ?
Gregaust- Posts : 626
The rest of the internals were very clean and the steels and clutches looked close to new.
Reused the case as a dummy trans for fitment.
XEngr- Posts : 71
» 4R100 trans case or core
» C 3 trans parts
» Tremec T56 with BBF
» broken or hurt parts
» Automatic o/d problem
» C 3 trans parts
