Custom sheetmetal efi A460 tunnel ram upper intake
Made from 3/16" 6061 and welded to the top of a dual Trick Flow carb plate top. Was going to use it for boosted efi and a 5" throttle body with 20 lbs of boost. Went with single plane intake instead. I have a Wilson 5" v band flange that hasnt been welded on it yet as well. I can open the intake and weld the flange on if desired or sold separately.
$350 OBO for the sheetmetal top without flange welded on. $425 with flange installed
octanehuffer- Posts : 101
Re: Custom sheetmetal efi A460 tunnel ram upper intake
Would like to talk to you about your sheet metal intake . My cell number is336-215-1571. Leave message if I don’t pick up. I work in parts for Ford in a large parts dept and sometimes can’t get right to the phone but I’ll return your call thanks Michael Mitchell
PROSTREET66- Posts : 245
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» trade tfs A460 intake for A460 tunnel ram or buy
» custom BG 4 port regulator bracket for TFS tunnel ram intake
» "Custom" A460 Intake
» Want To Trade A460 TFS Intake for Tunnel Ram
