Need a new cam!
Need a new cam! Empty Need a new cam!
Post  bbcoupe December 28th 2009, 5:43 am
Just broke a roller lifter in my 545 and thought I might take the opportunity to change cam, any thoughts on what to use?
Currently it's a Comp Cams XR292R, anyone had a cam ground specifically for a stroker or know of one more suited to a 545.
Specs are:
Stock block
Scat 9000 series 4.5in stroke crank
Eagle 6.8in H-beam rods
Probe dished forged pistons
Blue Thunder B heads (flow figures below)
Edelbrock Victor 4150 manifold
Barry Grant 1050 (3593020DR)
MSD 6530 Digital box, crank trigger & dissy
Running a C6 and 3:89 Locker 9in 28 in tall tyres
Need a new cam! Flows
bbcoupe
https://www.youtube.com/user/coupe545
Need a new cam! Empty Re: Need a new cam!
Post  the Coug December 28th 2009, 9:31 am
you are going to have to give alot more information than that for someone to help you pick a cam... they need car weight, engine size, intended use, converter stall, gear size, trans, intended use of the car, give one of the guy's here a call. Lem Evans, Randy Malik, Bret Powell, Scotty Johnston, Dave McLain, there are several more on here also just can't think of all of them.... No offense guy's...... any of them can and will help you......
Good luck
Post  bbcoupe December 28th 2009, 7:11 pm
1974 Australian Ford Falcon currently weighing 3900lbs. Used for weekend cruising and drag racing. Has a 3000 stall converter.
Need a new cam! DSC01830
bbcoupe
Post  XYPROSTREET December 28th 2009, 8:19 pm
Valve lift on that cam is too small for those cylinder heads but won't be long the experts will chime in and give you a better idea.
Good Luck & Nice Car
XYPROSTREET
Post  Mark Miller December 29th 2009, 1:15 am
bbcoupe,
That's one Bad Ass clean looking car you have,i love the looks of it.
Later Mark.
