Oil Pressure Standard Block vs. Aftermarket Block
Oil Pressure Standard Block vs. Aftermarket Block Empty Oil Pressure Standard Block vs. Aftermarket Block
Post  Daytonatunnel July 27th 2021, 12:54 pm
If all things internally are close to equal, would the oil pressure be similar with a standard block and an Eliminator block. Or does the priority oil system increase the oil pressure on the mains (reading from the typical BBF port at the back of the engine)?
Daytonatunnel
Daytonatunnel
Oil Pressure Standard Block vs. Aftermarket Block Empty Re: Oil Pressure Standard Block vs. Aftermarket Block
Post  dfree383 July 29th 2021, 8:08 am
It’s all in the clearances
Post  Gregaust July 30th 2021, 5:11 am
Been there previous with an Eliminator block. I've never studied the circuitry but I can say the pressure taken at the rear port is lower. Sad
We switched pressure reading to front port , all fixed Cool
Gregaust
Post  rmcomprandy July 30th 2021, 12:07 pm
Gregaust wrote:Been there previous with an Eliminator block. I've never studied the circuitry but I can say the pressure taken at the rear port is lower. Sad
I am not certain but, I think the rear port reads the pressure within the lifter galleries.
Gregaust likes this post
Post  Gregaust July 31st 2021, 5:48 am
At the time we contacted Eliminator gave us guidance to swap to the front port . We were only showing 40 psi at the rear .
Gregaust
Post  norm July 31st 2021, 9:36 am
Gregaust wrote: At the time we contacted Eliminator gave us guidance to swap to the front port . We were only showing 40 psi at the rear .
The difference in pressure at the front port and rear is just showing the "leaks" in the system front to back.
Too big of a drop would be bad i'd think. 10-20lbs is one thing but 50% would show a big issue
norm
norm
Post  rmcomprandy July 31st 2021, 1:40 pm
An Eliminator block and a standard production block are two totally different oiling systems.
