Gear Drive and Oil Temperature
Gear Drive and Oil Temperature Empty Gear Drive and Oil Temperature
Post  danski0224 August 28th 2021, 3:19 pm
I was curious if a gear drive has an effect on oil temperature.
Hotter or colder vs a timing chain.
I was not able to get "before" temperatures, but it isn't uncommon to be hitting 230 with the gear drive installed- and not really beating on it at all. Water temp rarely goes over 180 on the gauge.
danski0224
Gear Drive and Oil Temperature Empty Re: Gear Drive and Oil Temperature
Post  Curt August 29th 2021, 12:24 am
danski0224 wrote:I was curious if a gear drive has an effect on oil temperature.
Any time you compress a fluid it heats up.
Post  rmcomprandy August 29th 2021, 12:39 pm
I don't see any issue at all with 230 oil temp; exactly why do you have a concern ...? 225 is about perfect.
Post  danski0224 August 29th 2021, 1:06 pm
The indicated hot oil pressure is lower after the installation of a Kaase oil pump and Milodon gear drive.
Cold oil pressure with Amsoil 15w50 approaches 90 psi.
At operating temperature (water 180, oil about 230), oil pressure above 1500 rpm is 60 psi and it will go down to an approximate 14 psi in gear at idle at 800 rpm. The AutoMeter gauge starts at 10 psi.
Before the gear drive and different pump, the hot oil pressure was typically at 20 psi.
Old oil pump was a Milodon high pressure unit.
Pump was changed because of a pan swap to rear sump, which also holds more oil.
Engine had the gear drive installed a long time ago, decided to put it back in once I learned that it would work with a mechanical fuel pump.
danski0224
Post  Paul Kane August 30th 2021, 1:28 pm
Hotter or colder vs a timing chain...
Assuming it has been set up and installed correctly, there is nothing about a camshaft gear drive setup that will raise engine oil temperatures any discernable amount over an aftermarket roller timing chain setup.
QtrWarrior likes this post
