429 in foxbody
Hawaii808
429 in foxbody Empty 429 in foxbody
Post  Hawaii808 September 22nd 2021, 3:16 pm
I'm looking to install my 429 in my 89 Foxbody I bought the jegs conversion kit with the Hooker Headers oil pan and motor mounts. The Mustang I have came with a K member but for a small block Ford. What K member do I need to install the 429. Any help will be appreciated.
Hawaii808
429 in foxbody Empty Re: 429 in foxbody
Post  Mark Miller September 23rd 2021, 12:17 am
IIRC that V-8 K-Member should work with the Conversion Kit!!
Post  Hawaii808 September 23rd 2021, 2:10 pm
IlRC never heard of them.
Hawaii808
Post  pmrphil September 23rd 2021, 7:33 pm
IIRC = If I Remember Correctly , not a reference to any manufacturer.
pmrphil
Post  Hawaii808 September 23rd 2021, 7:55 pm
Aje sells a big block Ford k member. Do you recommend Aje.
Hawaii808
Post  Mark Miller September 24th 2021, 12:07 am
Hawaii808 wrote:IlRC never heard of them.
Never heard of them [who]?You said you have a K-Member for a Small Block Ford so that would be a V-8 FWIW i'm using the original 4 cylinder K-Member in my 89 Mustang and i'm using the Accufab 460 Swap Motor Mounts!!If you have an aftermarket SBF K-Member not sure if Jegs swap conversion mounts will work but i'm pretty sure they will with the factory Ford V-8 5.0 K-Member!!
Post  Mark Miller September 24th 2021, 12:12 am
Hawaii808 wrote:I'm looking to install my 429 in my 89 Foxbody I bought the jegs conversion kit with the Hooker Headers oil pan and motor mounts. The Mustang I have came with a K member but for a small block Ford. What K member do I need to install the 429. Any help will be appreciated.
It sounds like you bought the Fox Body 460 Swap Hooker Conversion Kit From Jegs?
Post  Hawaii808 September 24th 2021, 12:21 am
The k member l have in my foxbody now the BBF won't fit l have header issues the oil pan hits the k member. I didn't know that different k members fit only certain motors. This k member wint accept the 429.
Hawaii808
Post  Hawaii808 September 24th 2021, 12:23 am
So my question is what K member can I use to fit a 429 with the Jegs conversion kit motor mounts oil pan and Hooker Headers.
Hawaii808
Post  Mark Miller September 24th 2021, 2:41 am
Hawaii808 wrote:The k member l have in my foxbody now the BBF won't fit l have header issues the oil pan hits the k member. I didn't know that different k members fit only certain motors. This k member wint accept the 429.
I tried those Hooker Headers on my Mustang last year couldn't get them to fit took them back to Summit Racing had my MAC Headers[MAC no longer makes them] blasted and repainted them!! i'm going to bump a thread TTT for you in the Engine tech section about the Hooker Headers and Motor Mounts!!
Post  Hawaii808 September 24th 2021, 3:45 pm
Thank you. I live in Hawaii and shipping is outrageous l need the right information so l dont waste any more money.
Hawaii808
Post  rmcomprandy September 25th 2021, 12:47 am
Hawaii808 wrote:Thank you. I live in Hawaii and shipping is outrageous l need the right information so l dont waste any more money.
Use the kit from "Total Performance" in Michigan which uses a front motor plate and Mad Dog" headers. Stock K member with 1" spacers.
Post  BOSS 429 December 29th 2021, 2:04 am
I have installed them in 4cly cars with stock k menber. theres grinding to do on all of the stock members most of the time, rem the eng sits toward the pass side, not in the center
Mark Miller and 1982GT like this post
Post  TomW January 29th 2022, 1:46 pm
Hawaii,
I've used this install kit; had to make some tweaks with the headers but no major difficulties: http://ddautospec.com/products_engineswap.html
The tweaks consisted of notching a few of the primaries to accommodate the steering shaft. And, oh, yes, had to shorten the collectors, get rid of the three-bolt flanges and install V-band clamps to get enough clearance at that point.
It's in a 1981 Mercury Zephyr wagon (same as any Fox except longer wheelbase and yellow LOL); it uses a 1995 Fox Mustang V8 #2 crossmember.
16K street and track miles, no problems with that, yet...
Except once I forgot to check the motor mounts, a couple of bolts fell out. A day in the shop fixed that and all is OK since I put that item on my checklist.
Tom
TomW
http://www.firstcoastcobraclub.com
