95cc pistons
Maulerman1960
95cc pistons
I’m struggling to find pistons for my 460 to give me a 10 to 1 compression ratio with 95cc Procomp/Speedmaster heads. Is there a budget piston available that fits the bill?
Maulerman1960- Posts : 6
Re: 95cc pistons
Nothing that’s rebuilder cheap, a few companies do offer domed on the shelf pistons but they are usually in the $800 and up range. You might score some old used TRW/Speedpro domed pistons on the cheaper side, it they are heavy.
Re: 95cc pistons
Maulerman1960 wrote:I’m struggling to find pistons for my 460 to give me a 10 to 1 compression ratio with 95cc Procomp/Speedmaster heads. Is there a budget piston available that fits the bill?
A budget flat-top & zero decking the block is as close as you're going to get.
QtrWarrior and Mark Miller like this post
Re: 95cc pistons
”Budget” would be the Silvolite 3191HC flat top with press-fit rods. Deck block to 10.29” and use a Felpro blue 0.041” head gasket. Makes about 9.75:1 with a +0.030” and about 9.9:1 with a +0.060”. A really big flat tappet cam might dictate valve pocket machining; a smallish flat tappet cam may not with the 95cc Procomp head (other heads would need the bigger valve pocket regardless).Maulerman1960 wrote:I’m struggling to find pistons for my 460 to give me a 10 to 1 compression ratio with 95cc Procomp/Speedmaster heads. Is there a budget piston available that fits the bill?
Forged flat top pistons are made by several manufacturers but not as “budget” priced, relatively speaking.
Re: 95cc pistons
Thanks Randy and Paul. I will look into that scenario Paul.
Re: 95cc pistons
KB137 should get you close.
BigBlockRanger- Posts : 1267
Re: 95cc pistons
Flat top, deck high, .040 x 4.500 gasket and take the heads to 92ccs.
Bob's your uncle, Millie's your aunt.
Mark O'Neal- Posts : 286
» wtb eldelbrock 95cc heads
» WTT: edelbrock 75cc for 95cc heads
» rotating ass. push rods msd pistons ''''c-460 pistons added to rotating assembly''''
» WTB.....SCJ Pistons
» Still Looking 514/521 Pistons
