What Electric Fuel Pump ?
What Electric Fuel Pump ? Empty What Electric Fuel Pump ?
Post  lathechips January 25th 2022, 10:17 pm
Rerouting a fuel tank. How many GPH/PSI for a stock/mild build desmoged 74 / 460 in a 56 F100 ? Edelbrock & Holley 3310
lathechips
What Electric Fuel Pump ? Empty Re: What Electric Fuel Pump ?
Post  rmk57 January 25th 2022, 11:02 pm
This one should do the job.....
https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.jegs.com%2Fi%2FCarter%2F180%2FP4601HP%2F10002%2F-1&psig=AOvVaw1pr2lFAIStsvxofSo4C1_f&ust=1643252364673000&source=images&cd=vfe&ved=0CAwQjhxqFwoTCKj2x6S2zvUCFQAAAAAdAAAAABAD
rmk57
Post  Dave De January 26th 2022, 8:22 pm
I would think that 140 GPH is needed. A non-return system can be done with a Holley pump and regulator.
I think this package has both pump and regulator. 12-815-1
The red or blue pumps may work as well.
https://documents.holley.com/fuel_pump_tech_info.pdf
Post  rmk57 January 26th 2022, 10:03 pm
Reason I mentioned the Carter is you don't need a regulator. Another reason I mentioned the Carter is there quiet, much quieter than a dead headed Holley hammering away. If you need a bit more GPH then get the 4600 hp Carter. I think it's 120 GPH, but requires a regulator.
rmk57
