PCV alternatives
Gregaust
ChrisH
PCV alternatives
so, my goal here is to keep the blow by gases out of my intake, off the back side of my valve, etc hence why i am trying to avoid PCV.
i have a 578 that i spin up to 7000. it has a standard ring package (not thin in other words). during these higher revs there is certainly gases to evacuate.
i know the best answer would be a proper vacuum pump set for < 10" as this is a street driven engine. i have tried breathers and even a smog pump vacuum pump (electric)
neither were satisfactory. electric pump couldn't keep up. breathers hold more back pressure than i would like.
it seems besides a proper vac pump that i could just run an open draft tube or possibly header evacs. but, it seems the head evacs are not a good street solution.
so im down to a draft tube or pump (ironically the book ends of technology for this problem).
has anyone had a successful solution employed on a big street engine that revs a little?
i guess my fundamental question is what is the draw back to a draft tube?
thanks all
thanks all
ChrisH- Posts : 149
Re: PCV alternatives
http://mewagner.com/
What about this . I got one it is a real nice piece . To stop any oil put a oil separator inline maybe ?
Gregaust- Posts : 625
A small O.E.M electric power brake vacuum pump should work fine.
Down-Draft tubes worked well but, the EPA didn't accept the hydrocarbon emissions emitted from them.
I use a electric vacuum pump off a early 90s Chevy Comaro hooked from the valve cover to the evac in my headers. It works good I turn my 552 7200
akacolonel- Posts : 3
Gregaust and Mark Miller like this post
