Mid Plate spacer
Mid Plate spacer
I got a 1/4” ITC mid plate for my BBF. It comes with a spacer for the flex plate. Is it legit to just use the provided spacer or should I try & find a spacer that is “hub centric”?
nedceifus- Posts : 118
Re: Mid Plate spacer
What thanks are you using
I do not understand
dfree383 wrote:What thanks are you using
Do not use a spacer.
nedceifus likes this post
What trans are you using ? (Spell check)
It'd be a better option to have the converter modified
Gregaust- Posts : 625
C6
dfree383 wrote:What trans are you using ? (Spell check)
nedceifus wrote:C6dfree383 wrote:What trans are you using ? (Spell check)
Get the convertor built with the correct snout and bolt pad depths, specify it when you order the convertor.
Less loose parts the better
Gregaust and nedceifus like this post
Word, I’ll call PSC & see if they can rework my converter to be correct
Ha! I should have been able to decipher that!nedceifus wrote:I do not understanddfree383 wrote:What thanks are you using
» BBF to C-6 Spacer Plate,,, Anyone have one?
» BBF to C-6 spacer plate
» Phenolic Spacer Plate ?
» Cam thrust plate and water pump baking plate questions
» Injector plate above or below carb spacer
