Sr71 heads!
snuff98
pigs521bbf
Sr71 heads!
What part number do I need for head studs for my SR71 heads for an A460 block ?
pigs521bbf- Posts : 173
Re: Sr71 heads!
I got mine from Kaase, I think they are the same ones to fit the blue thunder heads. If in doubt call the man himself.
snuff98- Posts : 245
Re: Sr71 heads!
X2 on the call Kaase and even just get them from him, they will be the right stuff.
Re: Sr71 heads!
All of the studs and bolts are out of stock. Is it possible to cut an ARP stud to make it fit?
Re: Sr71 heads!
It would be possible, but you would need studs the are pretty close
Re: Sr71 heads!
255-4301 is the ARP part number for the studs, they do not make a bolt kit for them. I have been looking for the bolts for the Blue thunder heads so I can use them with my SR-71's no luck so far, good luck.
Dan
Dan
amthatiam- Posts : 3
Re: Sr71 heads!
Did everyone that makes performance parts and even engine bearings die from covid?
Re: Sr71 heads!
They are living just out of business!!!
wickettoby1- Posts : 352
Re: Sr71 heads!
Alot of it is basic material supply
Re: Sr71 heads!
.dfree383 wrote:Alot of it is basic material supply
It not only car parts it's machinery parts to it takes 3 times longer to get parts now everything out of stock. I ordered parts for a machine at work over a month ago and they still saying another 3 to 4 weeks. One of our packaging machines the company that builds them are now permanently closed. I ordered the stuff and going to build the part in house because all the machine shops are so far backed up.
Re: Sr71 heads!
69F100 wrote:.dfree383 wrote:Alot of it is basic material supply
"Build Back Better" is a real problem for anyone who doesn't have their head in the sand and a joke almost everywhere.
1EFF100 and Dave De like this post
Re: Sr71 heads!
Hang on, it is only going to get worse.
» Exhaust gaskets that fit SR71 heads?
» The new SR71 heads
» Kaase K1 cam vs. K2 cam in 521 with SR71 heads?
» Jon Kaase SR71 Cylinder Heads
» SR71 and Godzilla...
