all aluminum block 598 bbf p51 heads pump gas !
price reduced - $18,000
located in southern california.
this is a all aluminum 598 pump gas with 10.7 compressionc and c motorsports aluminum block,lunati crank,oliver billet rods,diamond pistons,fully ported p51 heads,comp 280-288 @.050 roller cam,trick flow intake,kaase rear sump pump,moroso pan,comp rockers,jessel solid body lifters,kaase/moroso valve covers,msd dist,engine only has a few pases on it,and runs great.needs only your carb.was in a 2700 pound mustang 9.60 index car.probably makes around 850 hp.does not come with flexplate.
hbstang- Posts : 362
nedceifus likes this post
598
can convert this to high compression boss heads with new piston i have for it.otherwise a great engine and deal as is it sits.
» saw this craigslist ..maybe you guys may want , Aluminum alan root block in NJ ...and heads
» *SOLD* 632 All-Aluminum Engine - C460 Heads, RDI Motorsport Block, CFE Intake, 3 Nitrous Kits
» FS: New set of Ford M-6049-SCJA aluminum cylinder heads.. HEADS SOLD, Thx
» aluminum water pump
