all aluminum block 598 bbf p51 heads pump gas !
all aluminum block 598 bbf p51 heads pump gas ! Empty all aluminum block 598 bbf p51 heads pump gas !
Post  hbstang September 16th 2022, 6:57 pm
price reduced - $18,000
located in southern california.
this is a all aluminum 598 pump gas with 10.7 compressionc and c motorsports aluminum block,lunati crank,oliver billet rods,diamond pistons,fully ported p51 heads,comp 280-288 @.050 roller cam,trick flow intake,kaase rear sump pump,moroso pan,comp rockers,jessel solid body lifters,kaase/moroso valve covers,msd dist,engine only has a few pases on it,and runs great.needs only your carb.was in a 2700 pound mustang 9.60 index car.probably makes around 850 hp.does not come with flexplate.
all aluminum block 598 bbf p51 heads pump gas ! Img_2711
all aluminum block 598 bbf p51 heads pump gas ! Img_2712
all aluminum block 598 bbf p51 heads pump gas ! Img_2713
nedceifus likes this post
all aluminum block 598 bbf p51 heads pump gas ! Empty nice engine
Post  hbstang November 7th 2022, 9:29 pm
bump
all aluminum block 598 bbf p51 heads pump gas ! Empty nice engine drivetrain
Post  hbstang April 19th 2023, 10:56 am
reduced price bump
all aluminum block 598 bbf p51 heads pump gas ! Empty 598
Post  hbstang February 19th 2024, 12:27 pm
can convert this to high compression boss heads with new piston i have for it.otherwise a great engine and deal as is it sits.i will keep it for my fairlane if i convert it to boss heads!
Post  hbstang July 4th 2024, 12:58 pm
bump
all aluminum block 598 bbf p51 heads pump gas ! Empty great engine
Post  hbstang October 27th 2024, 1:40 pm
this is a bad ass pump gas engine.can ship anywhere ,
all aluminum block 598 bbf p51 heads pump gas ! Empty Re: all aluminum block 598 bbf p51 heads pump gas !
