How To Remove Exhaust Manifold Bolts ?
How To Remove Exhaust Manifold Bolts ? Empty How To Remove Exhaust Manifold Bolts ?
Post  lathechips September 27th 2022, 9:56 pm
Looking for ideas how to remove exhaust manifold bolts? Yes I can go down the line & OH SHIT! - I'm trying to not happen. I don't want to pull the head or inner fenders ect. Trying not to screw my self - I need your ideas.
lathechips
How To Remove Exhaust Manifold Bolts ? Empty Re: How To Remove Exhaust Manifold Bolts ?
Post  dfree383 September 27th 2022, 10:44 pm
Depends on if you can get to the or not.
If they are inaccessible your bet to just pull the heads and save yourself a bunch of frustration and hard work
Post  69F100 September 28th 2022, 3:28 pm
I have used a propane torch to heat the manifold up around the bolts and work them loose sometimes it works and sometimes it doesn't
Post  ChrisH September 28th 2022, 10:49 pm
this is video is for a 7.3 but the principle is the same. this is what i have used as my methods
patience and heat+croil (or some equivalent) typically works, but if you can take heads off(knowing you don't want to go that route) you may be time ahead.
https://www.youtube.com/watch?v=9PKNCVXvZ6w
ChrisH
