How much Horsepower?
nedceifus
This is just a game, cause I’m bored & why not.
460 DIVE block
Stock crank
RaceTech forged pistons cut for SCJ 10.1
Custom cam solid roller 264/274 @50 410 lobe lift 110
Eagle SIR I beams
Victor 460 4150 port matched to heads
FMS SCJ heads, back cut intake valves stock ports
Comp ultra pro magnum rockers 1/7
Jomar rocker girdles
Jomar 1” power cone
AED HO 1000cfm 4150
Cloyes billet roller chain
MSD pro billet
MSD 6AL
460 DIVE block
Stock crank
Eagle SIR I beams
Jomar 1” power cone
AED HO 1000cfm 4150
MSD pro billet
MSD 6AL
nedceifus- Posts : 118
Re: How much Horsepower?
^ Same. More Compression and a 1050 Dominator would get around 700. You are going to beak your weak 9" and all you Axles U-Joints Posi pinion gears pinion support Transmission and everything else in between with what you have if it Hooks on the Spray. It's enough for now. Maybe the Controller will save it.
PS: Keep your fire extinguisher handy. A Nitrous backfire will set the big oil filled air filter ablaze pronto.
It looks good and the lower compression will help your fuel bill.
supervel45- Posts : 4499
nedceifus likes this post
650? Are the heads ported?
stanger68- Posts : 500
5 fidy.
Curt- Posts : 2791
No, stock
stanger68 wrote:650? Are the heads ported?
This should go on the dyno Thursday. Car is not near ready but I want to see what this old 460 can do. Hoping for 600.
Dyno results?
J.Toney- Posts : 398
Sorry, false alarm. Headers would not fit dyno. Ordered turbo headers & am going to be adding a little blow threw boost.
nedceifus wrote:Sorry, false alarm. Headers would not fit dyno. Ordered turbo headers & am going to be adding a little blow threw boost.
Nice. Are you going to go single or twin?
Stay Carburetored or go FI?
Single for simplicity & cost. Blow threw. Not looking to start the world on fire.
