Port Work Question
Port Work Question
Thinking of purchasing these A429 heads but they've been ported through the exhaust bolt boss. Seems a little extreme to me.
Just curious what your opinion is on this port job overall.
Please click on the mass of text to view.
Thanks.
https://www.facebook.com/marketplace/item/1282108445679104/?hoisted=false&ref=browse_tab&referral_code=marketplace_general&referral_story_type=general&tracking=%7B%22qid%22%3A%22-4870995730441653894%22%2C%22mf_story_key%22%3A%22991692431487771919%22%2C%22commerce_rank_obj%22%3A%22%7B%5C%22target_id%5C%22%3A991692431487771919%2C%5C%22target_type%5C%22%3A6%2C%5C%22primary_position%5C%22%3A44%2C%5C%22ranking_signature%5C%22%3A4110890005625307136%2C%5C%22commerce_channel%5C%22%3A501%2C%5C%22value%5C%22%3A0.00012580036357372%2C%5C%22upsell_type%5C%22%3A3523%2C%5C%22candidate_retrieval_source_map%5C%22%3A%7B%5C%229198543410171324%5C%22%3A3021%2C%5C%225735969413188939%5C%22%3A3002%2C%5C%225958818224178571%5C%22%3A3020%2C%5C%228555800661156694%5C%22%3A3502%2C%5C%225726888030764663%5C%22%3A3502%2C%5C%225910256855687413%5C%22%3A3502%7D%2C%5C%22grouping_info%5C%22%3Anull%7D%22%2C%22lightning_feed_qid%22%3A%22-4871049881430299260%22%2C%22lightning_feed_ranking_signature%22%3A%224110890005625307136%22%2C%22ftmd_400706%22%3A%22111112l%22%7D
Thanks.
1EFF100- Posts : 265
Re: Port Work Question
Did you see the ones Kasse did like that?
https://2img.net/h/i273.photobucket.com/albums/jj226/carmagguy/519StrokerPerformanceGuidepage4.jpg
No hardware except guide plates?
Are those the same ones as at the other site?
Can you check the throat diameter if they are local?
PS: Might want to check the serial numbers if you want to run 2.25" 1.76" valves in them.
https://www.429-460.com/t4560-a429-clipping-valves
supervel45- Posts : 4499
Don't know if they're the ones from the other site, I just saw them on FB.
Not local so unable to see them in person.
They have the same purple towel under them. Probably the same ones.
The pictures where better on the other site. I can link it if you have not seen them?
Sure. Let's have a look.
https://www.460ford.com/threads/are-these-heads-overworked.250887/
Maybe DFree will chime in?
It looks like they stopped porting about a 1/4" to 3/8" from the seats?
You are going to be in a race now, so don't quote if you want a chance at them.
Thanks for that.
Ehh..it's all right, I don't really need them. Just thought it would be nice to have in my stock, for a potential future build.
Yes sir. I have been adding to them. I have valves, guide plates and studs now. Just need a spring package for whatever cam that will be run with them.
[quote="1EFF100"]Thinking of purchasing these A429 heads but they've been ported through the exhaust bolt boss. Seems a little extreme to me.
Thanks.
This does help somewhat with airflow on these heads so, it is pretty common to see that.
However, most of the time, those head bolt holes are reamed to 5/8" and either brass or stainless thin wall tubing is installed so, exhaust carbon won't cling to the head bolt/stud, keeping them clean for much easier removal.
Thanks.
1EFF100 likes this post
1EFF100 wrote:Yes sir. I have been adding to them. I have valves, guide plates and studs now. Just need a spring package for whatever cam that will be run with them.
If you have a little cash I would grab 3 sets of springs, SFT, HFT and roller as well as cam bearings and a set of HFT and SFT lifters if you can, especially NOS on the lifters. I don't see prices going down and who knows on availibilty in the future.
I keep all that stuff on my watch list and it appears to be drying up, except maybe the springs.
» to the Evans? head port work
» Dove head port and chamber work
» heads with raised exhaust port question? also what spark plugs to run?
» will tfs A460 heads work on my d1ve block ? or do they only work on the race blocks
