Preferred Head Gasket
Installing a TFS A-460 18 bolt head onto a factory 10 bolt block. What is the preferred head gasket to use, a 10 or 18 bolt?
Thank you,
Tony.
Thank you,
Tony.
Tonyb- Posts : 9
Re: Preferred Head Gasket
I don't know if this will help you or not.
https://static.trickflow.com/global/images/instructions/tfs-dp-18.pdf
For what it's worth they show a FelPro 1028 below 4.660" bore diameter at the bottom of the link.
supervel45- Posts : 4499
Tonyb likes this post
Cometic 10 bolt
Lem has good ones with correct water holes available
Tonyb wrote:Installing a TFS A-460 18 bolt head onto a factory 10 bolt block. What is the preferred head gasket to use, a 10 or 18 bolt?
Thank you,
Tony.
Be sure to use a gasket with at least 4.600" bore on the TFS A460 heads regardless of the block bore.
QtrWarrior and Tonyb like this post
Lem Evans wrote:Tonyb wrote:Installing a TFS A-460 18 bolt head onto a factory 10 bolt block. What is the preferred head gasket to use, a 10 or 18 bolt?
Thank you,
Tony.
Thanks for the reply, pm sent Lem.
Tonyb- Posts : 9
Lem Evans likes this post
Tonyb wrote:Lem Evans wrote:Tonyb wrote:Installing a TFS A-460 18 bolt head onto a factory 10 bolt block. What is the preferred head gasket to use, a 10 or 18 bolt?
Thank you,
Tony.
Lem will get you fixed up with the proper parts.
lance flake- Posts : 142
Well, after a very short wait, Lem Evans has gotten me all fixed up with several items that I needed. He was a joy to visit with, and I am looking forward to placing another order with him when the time comes. Appreciate everyone’s responses, and wish you all a safe and fun racing season that cannot get here soon enough!
Tony.
Tony.
Tonyb- Posts : 9
Mark Miller and 2 wicked like this post
