Adding transfer fuel tank to an E
I have a 1992 E350 138WB club van 460\7.5 EFI E4OD that has a factory 35 gallon mid fuel tank w vented fuel cap. I am planning to add a 55 gallon fuel tank from a 1993 E350 460\7.5 EFI motorhome chassis to behind the axle of mine as a transfer fuel tank. I can handle the moving adding cross members.
Question if I use the stock EFI in-tank pump 55gal tank to supply the factory 35gal at the filler neck pipe using a aftermarket type T pipe works??
If i do transfer in 10 second intervals as I am driving doable or??
someone must have done something like this..... thanks.
Kobelco- Posts : 101
» half tank...but run out of fuel?
» Fox body gas tank and fuel pump
» Got the new fuel tank done ... Pics added
» Anyone Know a custom fuel tank shop
» Fox Body "Nitrous Enrichment Fuel Tank"
